WIFI timing
supertronic
WIFI timing
Postby supertronic » Mon Feb 13, 2017 1:36 pm
I need for power consumption calculations some timing informations.
How much time is needed to open wifi connection on access point, send a small block (1Kb) and close connection again?
Best regards
Michael
WiFive
Re: WIFI timing
Postby WiFive » Mon Feb 13, 2017 2:04 pm
Depends on a lot of things, maybe 5-10 seconds from powerup? Amazon dash button takes ~15sec to do its business.
supertronic
Re: WIFI timing
Postby supertronic » Tue Feb 14, 2017 7:05 am
Thank you for the fast reply.
My use case is a sensor connecting to Wifi and transmitting every second a short message.
How can I reduce the power consumption between the messages.
Will the Wifi connection got broken if I switch to a sleep mode and finally how much time do i need to wake up and send one frame again?
supertronic
Re: WIFI timing
Postby supertronic » Mon Mar 06, 2017 1:29 pm
Nobody has information about power saving schemes using WIFI connections?
Users browsing this forum: trendictionbot and 2 guests
