https://hubberthus.github.io/
The general idea was to have a tool for different kinds of modules using ESP32, and play visually with the pinout until I'm satisfied with the result.
Different boards route out different pins, and may have built-in pull-up resistors and stuff.
But the main reason I've been doing this is because of the GPIO_Matrix.
There are virtually no limits and it is better to do the setup by clicking and actually seeing what goes where.
The ultimate tool would then generate code: A layer which I can use in the application code, but I'm still pretty far away from that.
Actually I know I'm pretty far away now from reality. The tool has many faults in it.
I tried to make it the best I could using the documentations, schematics, etc. However I'm just a programmer who happens to like this chip, and play with it. There are things which are just in "???" category for me.
But even with its flaws it may be useful for others as well, so I've decided to share it.
