ESP32 Speed up loading
Adham Aboud
Postby Adham Aboud » Wed Jul 31, 2019 2:14 pm
Hello All,
Is there is a way to speed up the boot procedure with ESP32?
mikemoy
Re: ESP32 Speed up loading
Postby mikemoy » Wed Jul 31, 2019 10:38 pm
It's typically up and running in under <=1 second. Why are you needing it faster than that ?
WiFive
Postby WiFive » Thu Aug 01, 2019 12:02 am
Because batteries. Or because instant response (like a smart bulb remote).
https://github.com/espressif/esp-idf/pull/3304
Adham Aboud
Postby Adham Aboud » Thu Aug 01, 2019 6:46 am
Hello WiFive and thanks for your response.
I see that it's more than 1 second. I don't exactly know what is the booting time. I can measure it later
The need for faster boot is because of response to HW that needs to set a declared GPIO for high level before 1 second passes.
WiFive
Postby WiFive » Thu Aug 01, 2019 7:47 am
Well you may want to do that in custom bootloader then or wake stub if you are deepsleeping
Users browsing this forum: PerplexityBot, PetalBot, Semrush [Bot] and 1 guest
