I am using an ESP-WROOM-32 on a custom PCB in low RSSI conditions (e.g. RSSI shows -70 to -90 dBm) and the device has difficulty maintaining a stable wifi connection to the access point. Are there configuration/software changes to the WiFi configuration I can make to increase the longevity of the WiFi connection?
I have set modem power saving to WIFI_PS_NONE, which has helped somewhat.
I also see mention of "the default behavior of LwIP is to abort all TCP socket connections on receiving the disconnect" (https://docs.espressif.com/projects/esp ... sconnected) as referenced for situations to consider in which the default behavior may not be desirable.
Maintaining WiFi connection in low RSSI conditions
user4_esp32
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
