Can we use ESP32 or any other board from ESP for sending video to private server? If yes, which board can be used and what are the libraries available for the same?
Waiting for your early response.
Ritu
Sending video to Private Server
Re: Sending video to Private Server
HiHi,
Ritu
- how the private server is awaiting for video (StreamVideoFile, StreamVideofromESP_I2S_connectedCaptureCamera, StreamVideofromESP_CBS_VideoSignal.... )
- how the private server is communicate with Clients (ETH_LAN, Wifi, BT, BLE ... )
- how you want connect the ESP32 to the privat server? (Wifi, ETH_LAN, BT, BLE,....)
- how you want program your ESP32? (Arduino CODE, usually C/CPP, Python... )
also:
- how or / do you want process RAW/Packet video on ESP32 to send to privat server?
Waiting for the response.
rudi
HiHiHi,
Ritu
also:
rudi![]()
We will send video to amazon server over wifi. Programming the ESP32 shall be done by using make command provided by esp-idf.
Ritu
Hi RituHi
Ritu
you will send a video file or a video stream from just now to AWS ?
example, if you want send a video file for sharing (from sd card, from spi flash, from live stream... ) ,
you can do this by creating an AWS account tu use AWS.
if you are done with creating the account, you can use AWS and send the file to the created account cloud.
here is a szenario how you create AWS Account and how you connect ESP32 to the AWS account.
it is for "send and receive messages" but the Account creating is simular.
also, for your reference and info, there is ESP-AWS-IOT for the the ESP-IDF
have a look to this.
this framework enables AWS IoT cloud connectivity with ESP32 based platforms using AWS IoT Device Embedded SDK.
now pick the cherry things from the git repo, read the how to and readme and do what you want do and transfer your video file to AWS.
hope this helps for the begin in your work.
let the forum know how you go on in this and if you need any further help or if you get any problems.
rudi
Hi RituHi
Ritu
rudi![]()
Hi Rudi,
Which model of esp32 you are suggesting for this. I hope there would not be any memory issue in sending video file to the server, in the model you are suggesting. Also, we can send the video file to any server??
Ritu.
Hi Rudi,
Ritu.
Hi Ritu,
personally, I recommend using the CHIP REV > 0, then there is no problem with pSRAM and PLL.
see Eco and Workarounds for Bugs in ESP32
second, if you do not make your own module,
use espressif modules that adhere to PCBs and recommendations and standards.
that does not mean that other manufacturers make poor modules
and later make your own modules if you want it to become a product (or consult with Espressif, they also create custom modules, even with secure private keys)
yes, you can usually send the video file to any server, if the server accept "upload" (files).
example by http:post command or ftp:put command or ssh like you configure the "server" and what the "secure" technic need.
you can use https or sftp too and other with esp32.
personally i work /practice,training with different modules, ( DevKit, PicoD4Kit, Nano32, M5Stack )
they have different advantages, the m5stack is very cute and already with friendly housing and display, also lipo,
but there is also the wrover kit from espressif, with camera slot nice debug and further more etc.
for fast doing to ckeck code i use most of time M5Stack, PicoD4Kit, DevKitC, they are on the desktop every time
for experimental matters with measuring instruments oscilloscopes, etc I take own custom board and bare Wroom32 module / ESP32 Chip / ESP32PicoChip without any.
hope this helps
rudi
edit: there is a big maker board on (wrover32) edit: i mean wroom32
i have not tested but it looks big
