ESP32 External 32 KHz External Crystal How to Enable it
rsavage
Postby rsavage » Mon Aug 12, 2019 8:11 pm
I have a "Sparkfun ESP32 Thing" and a "Adafruit ESP32 Huzza" both have a external 32 KHz crystal available and I am using Arduino IDE for programming. To see if the external crystal is enabled I checked the "sdkconfig" file and it shows the following.
CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_RC=y
CONFIG_ESP32_RTC_CLOCK_SOURCE_EXTERNAL_CRYSTAL=
CONFIG_ESP32_RTC_CLOCK_SOURCE_EXTERNAL_OSC=
CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_8MD256=
Based on the above I conclude that the internal crystal is being used.
Using the Arduino IDE is there a way to set the External Crystal using "#define" or "set" commands in the Arduino code? Or can I just change the entry in the "sdkconfig" file to the following? And make sure that the other sources listed are not checked.
CONFIG_ESP32_RTC_CLOCK_SOURCE_EXTERNAL_CRYSTAL=y
Any help is greatly appreciated,
Users browsing this forum: Applebot, PetalBot and 2 guests
