Stopping esp timer generates exception
hetal.panara82
Postby hetal.panara82 » Mon Aug 19, 2019 4:26 pm
I am working with ESP32 Dev kit V1.
As I load example program, esp_timer from package it works fine and I see one shot timer and periodic timer working fine as expected.
However if I create a task and initialize timer (copy paste from example), I see timer is started as expected (based on the logs it prints). I have assigned a callback which,
1. printf a log statement
2. stop timer by calling, (code snippet attached)
ESP_ERROR_CHECK(esp_timer_stop(periodic_timer_handle));
Here, as soon as it calls stop timer, it generates exception and reboots. Any clue? It seems to be the same example code which I have added as part of my new task which I am calling from app_main routine.
After initializing the gpio and timer, task is there in while loop so as not to end it
/* GPIO Example
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include "freertos/task.h"
#include "freertos/queue.h"
#include "driver/gpio.h"
 * Brief:
 * This test code shows how to configure gpio and how to use gpio interrupt.
 * GPIO status:
 * GPIO18: output
 * GPIO19: output
 * GPIO4:  input, pulled up, interrupt from rising edge and falling edge
 * GPIO5:  input, pulled up, interrupt from rising edge.
 * Test:
 * Connect GPIO18 with GPIO4
 * Connect GPIO19 with GPIO5
 * Generate pulses on GPIO18/19, that triggers interrupt on GPIO4/5
#define GPIO_INPUT_IO_0     23
#define GPIO_INPUT_PIN_SEL  (1ULL<<GPIO_INPUT_IO_0)
#define ESP_INTR_FLAG_DEFAULT 0
static gpio_num_t switch_gpio_num;
static xQueueHandle gpio_evt_queue = NULL;
//static esp_timer_handle_t oneshot_timer;
static void oneshot_timer_callback(void* arg);
static esp_timer_create_args_t oneshot_timer_args;
static void IRAM_ATTR gpio_isr_handler(void* arg)
    uint32_t gpio_num = (uint32_t) arg;
    xQueueSendFromISR(gpio_evt_queue, &gpio_num, NULL);
static void gpio_switch_task(void* arg)
    printf("SP_DEBUG: starting gpio switch task\n");
    for(;;) {
        if(xQueueReceive(gpio_evt_queue, &switch_gpio_num, portMAX_DELAY)) {
            printf("GPIO[%d] intr, val: %d\n", switch_gpio_num, gpio_get_level(switch_gpio_num));
	    //ESP_ERROR_CHECK(esp_timer_stop(oneshot_timer));
	    //ESP_ERROR_CHECK(esp_timer_start_once(oneshot_timer, 1000000));
	}else {
	    printf("SP_DEBUG: nothing received from GPIO\n");
void switch_scan_task(void *pvParameters)
    switch_gpio_num = GPIO_INPUT_IO_0;
    gpio_config_t io_conf;
    //disable pull-down mode
    //io_conf.pull_down_en = 0;
    //disable pull-up mode
    //io_conf.pull_up_en = 0;
    //interrupt of rising edge
    io_conf.intr_type = GPIO_PIN_INTR_POSEDGE;
    //bit mask of the pins, use GPIO4/5 here
    io_conf.pin_bit_mask = GPIO_INPUT_PIN_SEL;
    //set as input mode
    io_conf.mode = GPIO_MODE_INPUT;
    //enable pull-up mode
    //io_conf.pull_up_en = 1;
    gpio_config(&io_conf);
    //change gpio intrrupt type for one pin
    gpio_set_intr_type(GPIO_INPUT_IO_0, GPIO_INTR_POSEDGE/*GPIO_INTR_ANYEDGE*/);
    //create a queue to handle gpio event from isr
    gpio_evt_queue = xQueueCreate(10, sizeof(uint32_t));
    //start gpio task
    xTaskCreate(gpio_switch_task, "gpio_switch_task", 2048, NULL, 10, NULL);
    //install gpio isr service
    gpio_install_isr_service(ESP_INTR_FLAG_DEFAULT);
    //hook isr handler for specific gpio pin
    gpio_isr_handler_add(GPIO_INPUT_IO_0, gpio_isr_handler, (void*) GPIO_INPUT_IO_0);
    //remove isr handler for gpio number.
    gpio_isr_handler_remove(GPIO_INPUT_IO_0);
    //hook isr handler for specific gpio pin again
    //One shot timer for switch glitch filtering
    //const esp_timer_create_args_t oneshot_timer_args = {
    oneshot_timer_args.callback = &oneshot_timer_callback;
       /* argument specified here will be passed to timer callback function */
       oneshot_timer_args.arg = (void*) oneshot_timer;
       oneshot_timer_args.name = "one-shot";
    ESP_ERROR_CHECK(esp_timer_create(&oneshot_timer_args, &oneshot_timer));
    ESP_ERROR_CHECK(esp_timer_start_periodic(oneshot_timer, 1000000));
#if 1
    int cnt = 0;
    while(1) {
        printf("cnt: %d\n", cnt++);
        vTaskDelay(1000 / portTICK_RATE_MS);
        //gpio_set_level(GPIO_OUTPUT_IO_0, cnt % 2);
        //gpio_set_level(GPIO_OUTPUT_IO_1, cnt % 2);
#endif
    //int64_t time_since_boot = esp_timer_get_time();
    //ESP_LOGI(TAG, "One-shot timer called, time since boot: %lld us", time_since_boot);
    printf("SP_DEBUG: oneshot timer : GPIO[%d] intr, val: %d\n", switch_gpio_num, gpio_get_level(switch_gpio_num));
    esp_timer_handle_t periodic_timer_handle = (esp_timer_handle_t) arg;
    /* To start the timer which is running, need to stop it first */
    //ESP_ERROR_CHECK(esp_timer_start_periodic(periodic_timer_handle, 1000000));
    //time_since_boot = esp_timer_get_time();
    //ESP_LOGI(TAG, "Restarted periodic timer with 1s period, time since boot: %lld us",
    //        time_since_boot);
Users browsing this forum: Bing [Bot], Google [Bot], Semrush [Bot] and 7 guests
