Loading image via JTAG adapter
Superkurt
Postby Superkurt » Thu Feb 16, 2017 12:29 am
I'm debugging the ESP32 with Eclipse, OpenOCD and an Olimex ARM-USB-OCD-H JTAG adapter. Normal debugging works fine, but during startup I can't load the executable into the ESP32. I'm using the GNU ARM Eclipse plugin from http://gnuarmeclipse.github.io/ to get the debugging working. In the startup settings of the debugger I can't check the "Load executable" option which loads the image into the ESP32. If I check this option and start debugging I get the following output from OpenOCD:
Open On-Chip Debugger 0.10.0-dev-g90071eb (2017-02-12-00:28)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 2000 kHz
force hard breakpoints
Started by GNU ARM Eclipse
Info : clock speed 2000 kHz
Info : esp32.cpu0: Debug controller was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32.cpu0: Core was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32.cpu0: Core was reset (pwrstat=0x1F, after clear 0x0F).
Info : esp32.cpu0: Target halted, pc=0x40000400
esp32.cpu0: target state: halted
Error: timed out while waiting for target halted
TARGET: esp32.cpu1 - Not halted
in procedure 'reset'
in procedure 'ocd_bouncer'
Info : Halt timed out, wake up GDB.
Info : Auto-detected RTOS: FreeRTOS
Error: esp32.cpu0: xtensa_write_memory (line 1024): DSR (8020CC13) indicates DIR instruction generated an exception!
Warn : esp32.cpu0: Failed writing 4096 bytes at address 0x3F400010
Warn : esp32.cpu0: Failed writing 4096 bytes at address 0x3F401010
Info : dropped 'gdb' connection
Should it be possible to load the executable during OpenOCD startup into the flash? Or why do I get the error:
Angus
Re: Loading image via JTAG adapter
Postby Angus » Thu Feb 16, 2017 1:34 am
At the moment the esp32 openocd driver doesn't include a flash driver, so you can't yet write to flash over JTAG. You have to flash via serial with esptool.py, then you can attach JTAG for debugging.
Superkurt
Postby Superkurt » Fri Feb 17, 2017 7:30 pm
Thanks for the explanation. By the way I've created a list of steps what I've done to get on-chip-debugging working with Eclipse. I've also a ready to use Virtual Box appliance. Maybe someone could use the information from here:
https://www.matthias-jentsch.de/2017/02 ... d-openocd/
zhivko
Postby zhivko » Mon May 08, 2017 3:40 pm
Flashing over JTAG would be really neat. Using 2 cables is not fancy ;).
@ESP_Angus: do you see this could be implemented in near future? I think it would help the platform to become mature and allow users to easier catch all this possible nasty bugs thata could happen during devel cycle.
f.h-f.s.
Postby f.h-f.s. » Tue May 09, 2017 8:25 am
VisualGDB can program the esp32 over JTAG, their version of openOCD https://github.com/sysprogs/openocd-esp32 has some extra functions. See https://esp32.com/viewtopic.php?f=2&t=854
I was thinking about trying to use their version of openOCD to do the same, but since debugging is not working for me at all, I stopped.
Users browsing this forum: Amazon [Bot], ChatGPT-User, Semrush [Bot] and 2 guests
