Variables losing value
sagar448
Postby sagar448 » Thu Aug 22, 2019 8:46 pm
Hey Guys,
This is my first post so apologies if I don't explain well.
Long story short....I am doing an AWS Iot project, I generate the openssl certificates in my nodejs backend and then I use the http client on the esp32 to send a request to my backend to give the esp32 the certificates. Certificates arrive fine, I parse it with cJSON and I can print it out. I then store the certificate in a global variable and then pass it to a function in the xTaskCreate.
The problem is that variable I pass doesn't keep the certificate value, when I print it out after passing it, I see some corrupted gibberish. The variables are devName, devCert and devKey!
Here is my entire code
Code: Untitled.c Select all
/* ethernet Example
#include <stdio.h>
#include <string.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_event_loop.h"
#include "esp_event.h"
#include "esp_log.h"
#include "esp_eth.h"
#include "rom/gpio.h"
#include "tcpip_adapter.h"
#include "driver/gpio.h"
#include "driver/periph_ctrl.h"
#include "eth_phy/phy_lan8720.h"
#include "esp_http_client.h"
#include "cJSON.h"
#include <sys/unistd.h>
#include <sys/stat.h>
#include "esp_err.h"
#include "esp_spiffs.h"
const int CONNECTED_BIT = BIT0;
char *devKey = NULL;
char *devCert = NULL;
char *devName = NULL;
int val = 0;
static EventGroupHandle_t ethernet_event_group;
#define DEFAULT_ETHERNET_PHY_CONFIG phy_lan8720_default_ethernet_config
static const char *TAG = "Spacr";
#define PIN_PHY_POWER 12
#define PIN_SMI_MDC 23
#define PIN_SMI_MDIO 18
static void phy_device_power_enable_via_gpio(bool enable)
assert(DEFAULT_ETHERNET_PHY_CONFIG.phy_power_enable);
if (!enable) {
DEFAULT_ETHERNET_PHY_CONFIG.phy_power_enable(false);
gpio_pad_select_gpio(PIN_PHY_POWER);
gpio_set_direction(PIN_PHY_POWER, GPIO_MODE_OUTPUT);
if (enable == true) {
gpio_set_level(PIN_PHY_POWER, 1);
ESP_LOGI(TAG, "Power On Ethernet PHY");
gpio_set_level(PIN_PHY_POWER, 0);
ESP_LOGI(TAG, "Power Off Ethernet PHY");
vTaskDelay(1);
if (enable) {
DEFAULT_ETHERNET_PHY_CONFIG.phy_power_enable(true);
//Setting up ethernet RMII mode
static void eth_gpio_config_rmii(void)
phy_rmii_configure_data_interface_pins();
phy_rmii_smi_configure_pins(PIN_SMI_MDC, PIN_SMI_MDIO);
//This is the function callback for ethernet events e.g. Ethernet Down, up etc.
static esp_err_t eth_event_handler(void *ctx, system_event_t *event)
tcpip_adapter_ip_info_t ip;
switch (event->event_id) {
case SYSTEM_EVENT_ETH_CONNECTED:
ESP_LOGI(TAG, "Ethernet Link Up");
case SYSTEM_EVENT_ETH_DISCONNECTED:
ESP_LOGI(TAG, "Ethernet Link Down");
case SYSTEM_EVENT_ETH_START:
ESP_LOGI(TAG, "Ethernet Started");
case SYSTEM_EVENT_ETH_GOT_IP:
memset(&ip, 0, sizeof(tcpip_adapter_ip_info_t));
ESP_ERROR_CHECK(tcpip_adapter_get_ip_info(ESP_IF_ETH, &ip));
ESP_LOGI(TAG, "Ethernet Got IP Addr");
ESP_LOGI(TAG, "~~~~~~~~~~~");
ESP_LOGI(TAG, "ETHIP:" IPSTR, IP2STR(&ip.ip));
ESP_LOGI(TAG, "ETHMASK:" IPSTR, IP2STR(&ip.netmask));
ESP_LOGI(TAG, "ETHGW:" IPSTR, IP2STR(&ip.gw));
xEventGroupSetBits(ethernet_event_group, CONNECTED_BIT);
case SYSTEM_EVENT_ETH_STOP:
ESP_LOGI(TAG, "Ethernet Stopped");
xEventGroupClearBits(ethernet_event_group, CONNECTED_BIT);
default:
return ESP_OK;
void spiffInit(){
esp_vfs_spiffs_conf_t spifConf = {
.base_path = "/spiffs",
.partition_label = NULL,
.max_files = 1,
.format_if_mount_failed = true
esp_err_t ret = esp_vfs_spiffs_register(&spifConf);
if (ret != ESP_OK) {
if (ret == ESP_FAIL) {
ESP_LOGE(TAG, "Failed to mount or format filesystem");
} else if (ret == ESP_ERR_NOT_FOUND) {
ESP_LOGE(TAG, "Failed to find SPIFFS partition");
ESP_LOGE(TAG, "Failed to initialize SPIFFS (%s)", esp_err_to_name(ret));
size_t total = 0, used = 0;
ret = esp_spiffs_info(NULL, &total, &used);
ESP_LOGE(TAG, "Failed to get SPIFFS partition information (%s)", esp_err_to_name(ret));
ESP_LOGI(TAG, "Partition size: total: %d, used: %d", total, used);
void parseDeviceCerts(char *data){
cJSON *dataJson = cJSON_Parse(data);
if (dataJson == NULL)
const char *error_ptr = cJSON_GetErrorPtr();
if (error_ptr != NULL)
fprintf(stderr, "Error before: %s\n", error_ptr);
esp_restart();
}else{
spiffInit();
struct stat st;
if (stat("/spiffs/deviceInfo.txt", &st) == 0 ) {
if (val == 1){
devKey = cJSON_GetObjectItem(dataJson, "key")->valuestring;
}else{
devCert = cJSON_GetObjectItem(dataJson, "cert")->valuestring;
esp_vfs_spiffs_unregister(NULL);
}else{
devName = cJSON_GetObjectItem(dataJson, "name")->valuestring;
FILE* f = fopen("/spiffs/deviceInfo.txt", "w");
if (f == NULL) {
ESP_LOGE(TAG, "Failed to open file for writing");
abort();
fprintf(f, devName);
fclose(f);
esp_restart();
cJSON_Delete(dataJson);
esp_err_t _http_event_handler(esp_http_client_event_t *evt)
switch(evt->event_id) {
case HTTP_EVENT_ERROR:
ESP_LOGD(TAG, "HTTP_EVENT_ERROR");
case HTTP_EVENT_ON_CONNECTED:
ESP_LOGD(TAG, "HTTP_EVENT_ON_CONNECTED");
case HTTP_EVENT_HEADER_SENT:
ESP_LOGD(TAG, "HTTP_EVENT_HEADER_SENT");
case HTTP_EVENT_ON_HEADER:
ESP_LOGD(TAG, "HTTP_EVENT_ON_HEADER, key=%s, value=%s", evt->header_key, evt->header_value);
case HTTP_EVENT_ON_DATA:
ESP_LOGD(TAG, "HTTP_EVENT_ON_DATA, len=%d", evt->data_len);
if (!esp_http_client_is_chunked_response(evt->client)) {
ESP_LOGI(TAG, "Data Recieved");
parseDeviceCerts((char*)evt->data);
case HTTP_EVENT_ON_FINISH:
ESP_LOGD(TAG, "HTTP_EVENT_ON_FINISH");
case HTTP_EVENT_DISCONNECTED:
ESP_LOGD(TAG, "HTTP_EVENT_DISCONNECTED");
return ESP_OK;
extern void aws_task_run();
void aws_task(void *pvParameter)
xEventGroupWaitBits(ethernet_event_group, CONNECTED_BIT, false, true, portMAX_DELAY);
aws_task_run(devName, devCert, devKey);
void sendRequest(char url[], char pData[]){
esp_http_client_config_t configg = {
.url = url,
.event_handler = _http_event_handler,
.buffer_size = 6000,
esp_http_client_handle_t client = esp_http_client_init(&configg);
const char *post_data = pData;
esp_http_client_set_method(client, HTTP_METHOD_POST);
esp_http_client_set_header(client, "Content-Type", "application/json");
esp_http_client_set_post_field(client, post_data, strlen(post_data));
esp_err_t err = esp_http_client_perform(client);
if (err == ESP_OK) {
ESP_LOGI(TAG, "Request Finished");
esp_http_client_cleanup(client);
void app_main()
tcpip_adapter_init();
//spiffInit();
//unlink("/spiffs/deviceInfo.txt");
ethernet_event_group = xEventGroupCreate();
ESP_ERROR_CHECK(esp_event_loop_init(eth_event_handler, NULL));
eth_config_t config = DEFAULT_ETHERNET_PHY_CONFIG;
config.phy_addr = 0;
config.gpio_config = eth_gpio_config_rmii;
config.tcpip_input = tcpip_adapter_eth_input;
config.clock_mode = 3;
config.phy_power_enable = phy_device_power_enable_via_gpio;
ESP_ERROR_CHECK(esp_eth_init(&config));
ESP_ERROR_CHECK(esp_eth_enable());
ESP_LOGI(TAG, "Connected to Internet success!");
spiffInit();
struct stat st;
ESP_LOGI(TAG, "File exists");
FILE* deviceInfo = fopen("/spiffs/deviceInfo.txt", "r");
if (deviceInfo == NULL) {
ESP_LOGI(TAG, "Failed to open file for reading");
abort();
char line[8];
fgets(line, sizeof(line), deviceInfo);
fclose(deviceInfo);
devName = line;
cJSON *root = cJSON_CreateObject();
cJSON_AddItemToObject(root, "name", cJSON_CreateString(line));
sendRequest("http://172.16.1.128:3000/getDeviceCertificate", cJSON_PrintUnformatted(root));
val = 1;
sendRequest("http://172.16.1.128:3000/getDeviceKey", cJSON_PrintUnformatted(root));
cJSON_Delete(root);
}else{
ESP_LOGI(TAG, "First time boot");
sendRequest("http://172.16.1.128:3000/createDeviceCertificate","{\"cACert\":\"myCAcertificate\"}");
xTaskCreate(aws_task, "aws_task", 10000, NULL, 5, NULL);
Please help!
jcsbanks
Re: Variables losing value
Postby jcsbanks » Fri Aug 23, 2019 7:59 am
I am only looking on a phone, but the global is a pointer and the string it points to is probably going out of scope when you delete after getting the JSON. I would investigate the lifetime and location of the string, and who is supposed to allocate and free memory.
https://github.com/DaveGamble/cJSON/issues/154
Users browsing this forum: ChatGPT-User, PerplexityBot and 3 guests
