ESP32-CAM + LAN8720
be-20-bb
ESP32-CAM + LAN8720
Postby be-20-bb » Sat Aug 31, 2019 10:18 am
Is it possible to combine ESP32-CAM with a LAN8720 for wired ethernet access? It seems I'd run out of pins.
What I'd need is: ESP + Camera + Ethernet.
WiFive
Re: ESP32-CAM + LAN8720
Postby WiFive » Sun Sep 01, 2019 5:39 am
You could try SPI Ethernet in parallel with the SD card
be-20-bb
Postby be-20-bb » Mon Sep 02, 2019 6:22 am
This is great, thanks a lot!
Bruno_Laboral
Postby Bruno_Laboral » Sun Dec 29, 2019 5:02 pm
I also have the same problem. Connect ESP32-CAM to wired Ethernet unis LAN8720.
Do you solve it? In this case could you share the information?
