[JTAG] [openocd] Error: DIR instruction generated an overrun!
aldecei
Postby aldecei » Thu Sep 05, 2019 12:22 pm
So I have that error since severals days:
Hardware
  • Esp32 devkit v1
  • Wroom32 With Jtag port (those 6 little dots)
  • jtag interface: SEGGER jlink
Problem
I type:
bin\openocd -s share\openocd\scripts -f interface\jlink.cfg -f board\esp-wroom-32.cfg -c "program_esp32 c:\xxxxxxxxxxxxxxxxxxxxxxx\bootloader.bin 0x1000 verify; program_esp32 c:\xxxxxxxxxxxxxxxxxxxxxxxxxxxxx\ethernet_demo.bin 0x10000 verify; reset; exit"
I get:
adapter speed: 20000 kHz
esp32 interrupt mask on
Info : No device selected, using first device.
Info : J-Link V10 compiled Jul 23 2019 13:46:10
Info : Hardware version: 10.10
Info : VTarget = 3.310 V
Info : Reduced speed from 20000 kHz to 15000 kHz (maximum).
Info : clock speed 20000 kHz
Info : esp32: Debug controller 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Debug controller 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 1 was reset (pwrstat=0x5F, after clear 0x0F).
Error: cpu0: esp32_fetch_all_regs (line 227): DSR (00000088) indicates DIR instruction generated an overrun!
Error: cpu1: esp32_fetch_all_regs (line 227): DSR (00000088) indicates DIR instruction generated an overrun!
Info : Target halted. PRO_CPU: PC=0x400E7EF2 (active) APP_CPU: PC=0x00000000
Error: cpu0: xtensa_write_memory (line 761): DSR (8000CC13) indicates DIR instruction generated an exception!
Warn : esp32: Failed writing 4 bytes at address 0x3FF5F064, data - a1, 3a, d8, 50, a1, 3a, d8, 50
embedded:startup.tcl:21: Error:
in procedure 'program_esp32'
in procedure 'reset' called at file "share\openocd\scripts/target/esp32.cfg", line 120
in procedure 'ocd_bouncer'
in procedure 'ocd_process_reset'
in procedure 'ocd_process_reset_inner' called at file "embedded:startup.tcl", line 248
in procedure 'esp32' called at file "embedded:startup.tcl", line 312
in procedure 'esp_core_halt'
in procedure 'esp32' called at file "share\openocd\scripts/target/esp32.cfg", line 44
at file "embedded:startup.tcl", line 21
Info : Detected debug stubs @ 3ffc0448 on core0 of target 'esp32'
Error: cpu0: xtensa_read_memory (line 654): DSR (00000088) indicates DIR instruction generated an overrun!
Warn : cpu0: Failed reading 76 bytes at address 0x50000000
Error: esp32_soc_reset 528 err=-4
embedded:startup.tcl:454: Error: ** Unable to reset target **
in procedure 'program_error' called at file "share\openocd\scripts/target/esp32.cfg", line 121
at file "embedded:startup.tcl", line 454
note: if i don't put commands I get no error:
If you have any idea I would be glad to hear it.
Re: [JTAG] [openocd] Error: DIR instruction generated an overrun!
Postby Sprite » Fri Sep 06, 2019 1:34 am
Can you try reducing your jtag speed? Perhaps your cables are too long or prone to noise.
aldecei
Postby aldecei » Fri Sep 06, 2019 10:35 am
Thanks, it works !
I went into the both cfg files (esp-wroom-32.cfg & jlink.cfg) and wrote adapter_khz 10000.
The problem is that openocd used to say that 20000khz is to much and change it to 15000khz. But 15000khz is still too much so it gives an error but that error do not mention any speed issues. So it's impossible to know that the problem is the adapter speed.
Anyway, thank you.
Users browsing this forum: Google [Bot], Qwantbot and 1 guest
