abort() was called at PC 0x40081e43 on core 1
mehrdadco
Postby mehrdadco » Mon Sep 16, 2019 12:27 pm
where is the problem
Code: Untitled.txt Select all
An interrupt as occurred. Total number: 1
Appending to file: /hello.txt
Backtrace: 0x4008c710:0x3ffbbbb0 0x4008c93d:0x3ffbbbd0 0x40081e43:0x3ffbbbf0 0x40081f3d:0x3ffbbc20 0x400db227:0x3ffbbc40 0x400dbcd9:0x3ffbbdb0 0x4000bcc5:0x3ffbbdd0 0x400dc9a5:0x3ffbbdf0 0x400d1c82:0x3ffbbe10 0x400d1393:0x3ffbbe90 0x400d123d:0x3ffbbec0 0x400d12cd:0x3ffbbf00 0x40080eb8:0x3ffbbf20 0x40081c89:0x3ffbbf40 0x4008232d:0x3ffbbf60 0x400f1b83:0x3ffbc020 0x400ddf07:0x3ffbc040 0x4008a5d2:0x3ffbc060 0x40088725:0x3ffbc080
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1100
load:0x40078000,len:9232
load:0x40080400,len:6400
i need append data to my file every 1 second
is there any other way?
Re: abort() was called at PC 0x40081e43 on core 1
Postby Sprite » Tue Sep 17, 2019 3:13 am
Moving to Arduino subforum. I suggest you double-check what restrictions the Arduino environment has for interrupt handlers; in plain ESP-IDF that would be your issue.
Users browsing this forum: Amazon [Bot] and 1 guest
