How is it possible the on pcb antenna version (WROOM02) connects better than the external antenna version (WROOM02U)?
sarpdaltaban
Postby sarpdaltaban » Fri Sep 20, 2019 8:58 am
Hello all,
I have tested both the on antenna version ESP-WROOM-02 and the external antenna version ESP-WROOM-02U.
How is it possible the pcb antenna version (ESP-WROO-02) is more successful than external antenna version(ESP-WROOM-02U) in terms of connectivity?
I have applied AT+RFPOWER=82 for both modules and the same test which consists same access points for the internet and same servers.
I have attached the suggested antenna and realized that the on pcb antenna module has a better connectivity.
Any help is appreciated
Kind Regards
WiFive
Re: How is it possible the on pcb antenna version (WROOM02) connects better than the external antenna version (WROOM02U)
Postby WiFive » Fri Sep 20, 2019 10:28 am
Did you force calibration with antenna attached by erasing flash or setting always calibrate mode?
WiFive
Postby WiFive » Fri Sep 20, 2019 1:37 pm
Wroom-02 uses esp8266 so go here for support https://bbs.espressif.com/
Users browsing this forum: Baidu [Spider], Bing [Bot], ChatGPT-User and 1 guest
