ESP32 Flash SPI Speed Issues
autodog
Postby autodog » Sat Sep 21, 2019 5:50 am
Hey everyone,
I have an ESP32-WROVER-B on multiple custom PCBs with an issue I can't explain:
- If I set the menuconfig -> Serial flasher config -> Flash SPI speed to 26, 40, or 80MHz I can flash an image successfully but I will receive a checksum error when the device reboots
- If I set the menuconfig -> Serial flasher config -> Flash SPI speed to 20MHz everything seems to run OK
Is this SPI flash speed expected? If not, any ideas what might cause my issues?
Thanks!
-AD
Re: ESP32 Flash SPI Speed Issues
Postby Sprite » Mon Sep 23, 2019 4:16 am
What does the custom PCB look like? Do you have anything connected to the flash pins that may affect operation?
WiFive
Postby WiFive » Mon Sep 23, 2019 4:28 am
Also make sure you are not pulling up gpio12 or have set the vdd_sdio efuse to 3.3v
autodog
[solved[ Re: ESP32 Flash SPI Speed Issues
Postby autodog » Tue Sep 24, 2019 1:30 am
ESP_Sprite:
You're right on the money: I had an I2C device hanging off of GPIO21 and 22 which also happen to be used by SPI flash on the ESP32-WROVER. This was causing my SPI Flash to be very flaky.
Removing my device from those two GPIOs cleared everything up.
Thanks for the pro-tip!
-AD
WiFive
Postby WiFive » Tue Sep 24, 2019 2:45 am
Do you mean pad 21&22 aka gpio 7&8?
