I am trying to run the nvs examples from https://github.com/espressif/esp-idf/tr ... s_rw_value
when flash it on esp32 , i get the below error
▒▒▒▒▒▒▒▒***ERROR*** A stack overflow in task ipc1 has been detected.
abort() was called at PC 0x400853a0
Guru Meditation Error: Core 1 panic'ed (abort)
Backtrace: 0x40009203:0x3ffe7ce0 0x00000000:0x3ffe7d00 0x40082c18:0x3ffe7d20 0x40084a37:0x3ffe7d40 0x40083f40:0x3ffe7d60 0x40080ae0:0x3ffe7d80 0x40007c34:0x3ffe7dc0 0x40000740:0x3ffe7e30
can anyone let me know how to resolve this . I am using the latest esp idf library.
Thank you
Paul
stack overflow using nvs
Re: stack overflow using nvs
Just tried the sample with the latest master, and it seems to work okay...
Which development board are you using?
Can anyone else reproduce this?
I am using Sparkfun-thing(ESP32) on windows. Same stack overflow on both esp32.
We have reproduced an issue which is similar to it (although the output is not exactly the same). We'll have a fix for is in master shortly.
Users browsing this forum: Barkrowler, Qwantbot and 2 guests
