general Issues on examples with used hardware there ( tlk110...)
Postby rudi ;-) » Wed Feb 22, 2017 10:38 pm
hi guys
a please to you developers at espressif who build example code for the idf:
can you please refer to the used hardware in your example
with shematic and used hardware, pins and used ESP32 Board?
there are more ESP32 Boards on the market and each has other hardware reference.
this would help in future us to test and build the same environment on hardware
and test your examples like you have wrote and thinked in code
cause this is a general theme it will post the same in esp32 github
https://github.com/espressif/esp-idf/issues/373
thank you for your understanding!
Angus
Re: general Issues on examples with used hardware there ( tlk110...)
Postby Angus » Wed Feb 22, 2017 11:13 pm
Regarding ethernet exmaples & hardware, there will be a reference design available soon (final revision are being done now). Once the reference design is final, the schematic will be published and the examples will refer to this design.
Regarding the other examples, if there are hardware details that are missing from a particular example please let us know and we will add them to the README.
Postby rudi ;-) » Wed Feb 22, 2017 11:18 pm
thank you
I will put it to memory after 8 days to ask for it.
i will do this in future
but better, the developer who create the example write in readme
that just in time this only a code in theoretical and not tested and later comes a reference design
and can be that code must be changed....
