ESP32 IDF Benchmark
fasani
Contact:
ESP32 IDF Benchmark
Postby fasani » Mon Oct 07, 2019 4:08 pm
I'm starting very slowly, since is hard to find time, a ESP32 Benchmark code for IDF
https://github.com/martinberlin/ESP32-benchmark
I will love to receive ideas, for example, to do interesting benchmarks that can also be compiled and uploaded in the coming soon ESP32S2 board with one LX7 Core.
So far in my list:
  • - Compression (Brotli, maybe GZIP)
    - Doing things while WiFi load (UDP / TCP)
    - Sending data via RMT (Addressable LEDs for example)
    - Reading / Writing in SPIFFs
    - Simple benchmarks
    - Any other idea?
Has someone already did something in this direction?
I've seen Arduino Benchmarks but I'm more interested in ESP32 WiFi and processing capabilities at the same time that go by far faster than on Atmel AVR chips
epdiy collaborator | http://fasani.de Fan of Espressif MCUs and electronic design
nicolasmm
Re: ESP32 IDF Benchmark
Postby nicolasmm » Fri Jan 31, 2020 7:54 pm
Maybe you could test the encryption capabilities in HTTPS or something like that.
fasani
Contact:
Postby fasani » Tue May 26, 2020 5:48 am
Thanks Nicola,
I'm actually building my first Epaper driver with Espressif's IDF so that will give me a steep learning curve. So when I get there I will retake this again and add your request to the list although I don't have any idea how to measure this, I guess opening an HTTPS connection and downloading 1 MB of information could be a good start.
nopnop2002
Contact:
Postby nopnop2002 » Tue Jul 20, 2021 6:47 am
fasani
Contact:
Postby fasani » Tue Aug 17, 2021 8:25 am
Thanks nopnop!
Didn't know about this one. I will try it out and compare speeds.
cruz000
Postby cruz000 » Thu Mar 16, 2023 11:16 pm
Take a look at a MDPI Sensors article related to benchmark using scheduler traces: TLS Protocol Analysis Using IoTST—An IoT Benchmark Based on Scheduler Traces
jgustavoam
Contact:
Postby jgustavoam » Sat Apr 06, 2024 7:50 pm
I found this:
ESP-IDF vs Arduino Framework: Best Framework for ESP32-S3 Development.
https://youtu.be/O-7rPkya4Yw?si=RXYms3a-rAEXvoRl
Retired IBM Brasil
