I2C Pins on ESP32-PICO-KIT V4.1
Serena Yeoh
Postby Serena Yeoh » Wed Oct 16, 2019 3:40 am
I apologized if this is a dumb question, I am new to ESP32 and not from EE background. I would like to know where are the I2C pins on the ESP32-PICO-KIT. I cannot find much information on this board and I can't see any labels for the SDA and SCL pins in the documentation on the espressif site. I have tried pins 21 and 22 which are the usual pins for ESP32-WROOM-32 Dev Kits but they don't work for the ESP32-PICO-KIT.
I would very much appreciate your help.
Thank You.
WiFive
Re: I2C Pins on ESP32-PICO-KIT V4.1
Postby WiFive » Wed Oct 16, 2019 4:45 am
You can route i2c pins to almost any gpio, that's why there is i2c_set_pin function
https://docs.espressif.com/projects/esp ... i2c_mode_t
mikemoy
Postby mikemoy » Wed Oct 16, 2019 6:10 pm
I am not sure what to say here because moving my I2C project from my ESP32-WROOM-32 Dev Kit worked just fine on the Pico Kit using the same pins. Do you have a ESP32-WROOM-32 Dev Kit, that you tried the I2C on first ?
dhanishvijayan
Postby dhanishvijayan » Sat Apr 03, 2021 1:03 pm
The default I2C pins if you choose pico32 as the board in the platformio is
IO22 - SCL
IO21 - SDA
Users browsing this forum: Google [Bot], Qwantbot and 4 guests
