Real firmware size
vjacobs
Real firmware size
Postby vjacobs » Sat Oct 19, 2019 9:24 am
Hi all,
I've searched around for this on the docs and this forum but can't find a conclusive answer. Which firmware size counts when calculating remaining space with regards to the given partition table?
For example: I'm having a standard OTA partition table:
# Espressif ESP32 Partition Table
# Name,   Type, SubType, Offset,  Size, Flags
nvs,      data, nvs,     0x9000,  0x4000,
otadata,  data, ota,     0xd000,  0x2000,
phy_init, data, phy,     0xf000,  0x1000,
factory,  0,    0,       0x10000, 1M,
ota_0,    0,    ota_0,  0x110000, 1M,
ota_1,    0,    ota_1,  0x210000, 1M,
The output of make size on my project is:
Total sizes:
 DRAM .data size:   12764 bytes
 DRAM .bss  size:  105184 bytes
Used static DRAM:  117948 bytes (  62788 available, 65.3% used)
Used static IRAM:   73409 bytes (  57663 available, 56.0% used)
      Flash code:  663732 bytes
    Flash rodata:  313472 bytes
Total image size:~1063377 bytes (.bin may be padded larger)
Since 1063377 > 1048576 (1M = 1024*1024), I suppose what counts is 663732+313472=977204 bytes then?
Thanks,
Vincent
WiFive
Re: Real firmware size
Postby WiFive » Sat Oct 19, 2019 11:34 am
No, actual bin size.
vjacobs
Postby vjacobs » Sat Oct 19, 2019 1:15 pm
Thanks WiFive for your answer, but then I'm over the limit of one partition of 1M, no? (1063377 > 1048576).
I would expect a warning or error in this case?
Best
Vincent
WiFive
Postby WiFive » Sun Oct 20, 2019 2:09 am
Bin may actually be smaller than image size but no I think you only get an error if you exceed flash size not partition size
Users browsing this forum: Bing [Bot], Qwantbot and 2 guests
