TCP server is slow
koryckid
TCP server is slow
Postby koryckid » Thu Oct 24, 2019 5:55 am
Hello, i am new in freertos and esp32.
I am working on the fastest speed with transmission packet over tcp socket,
I have TCP server on esp32, and from laptop ( both device connected to router) i send with netcat a bytes.
Program is one's from example esp-idf esp32 received fata and send back.
I am using wireshark to measure the time sending two bytes from laptop to esp and from esp to laptop.
Time is very big and because it takes ~150 ms and it is not constant for every time.
I set RTOS CLOCK to 1000HZ.
Do you have any idea how to speed up this transmission
Code: Untitled.c Select all
/* BSD Socket API Example
#include <string.h>
#include <sys/param.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "esp_event_loop.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "lwip/err.h"
#include "lwip/sockets.h"
#include "lwip/sys.h"
#include <lwip/netdb.h>
/* The examples use simple WiFi configuration that you can set via
'make menuconfig'.
If you'd rather not, just change the below entries to strings with
the config you want - ie #define EXAMPLE_WIFI_SSID "mywifissid"
#define EXAMPLE_WIFI_SSID CONFIG_WIFI_SSID
#define EXAMPLE_WIFI_PASS CONFIG_WIFI_PASSWORD
#define PORT CONFIG_EXAMPLE_PORT
/* FreeRTOS event group to signal when we are connected & ready to make a request */
static EventGroupHandle_t wifi_event_group;
const int IPV4_GOTIP_BIT = BIT0;
static const char *TAG = "example";
static esp_err_t event_handler(void *ctx, system_event_t *event)
switch (event->event_id) {
case SYSTEM_EVENT_STA_START:
esp_wifi_connect();
ESP_LOGI(TAG, "SYSTEM_EVENT_STA_START");
case SYSTEM_EVENT_STA_CONNECTED:
ESP_LOGI(TAG, "SYSTEM_EVENT_STA_CONNECTED");
case SYSTEM_EVENT_STA_GOT_IP:
xEventGroupSetBits(wifi_event_group, IPV4_GOTIP_BIT);
ESP_LOGI(TAG, "SYSTEM_EVENT_STA_GOT_IP");
case SYSTEM_EVENT_STA_DISCONNECTED:
/* This is a workaround as ESP32 WiFi libs don't currently auto-reassociate. */
esp_wifi_connect();
xEventGroupClearBits(wifi_event_group, IPV4_GOTIP_BIT);
default:
return ESP_OK;
static void initialise_wifi(void)
tcpip_adapter_init();
wifi_event_group = xEventGroupCreate();
ESP_ERROR_CHECK( esp_event_loop_init(event_handler, NULL) );
ESP_ERROR_CHECK( esp_wifi_set_storage(WIFI_STORAGE_RAM) );
wifi_config_t wifi_config = {
.sta = {
.ssid = EXAMPLE_WIFI_SSID,
.password = EXAMPLE_WIFI_PASS,
ESP_LOGI(TAG, "Setting WiFi configuration SSID %s...", wifi_config.sta.ssid);
ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_STA) );
ESP_ERROR_CHECK( esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config) );
static void wait_for_ip()
uint32_t bits = IPV4_GOTIP_BIT;
ESP_LOGI(TAG, "Waiting for AP connection...");
xEventGroupWaitBits(wifi_event_group, bits, false, true, portMAX_DELAY);
ESP_LOGI(TAG, "Connected to AP");
static void tcp_server_task(void *pvParameters)
char rx_buffer[128];
char addr_str[128];
int addr_family;
int ip_protocol;
while (1) {
struct sockaddr_in destAddr;
destAddr.sin_addr.s_addr = htonl(INADDR_ANY);
destAddr.sin_family = AF_INET;
destAddr.sin_port = htons(PORT);
addr_family = AF_INET;
ip_protocol = IPPROTO_IP;
inet_ntoa_r(destAddr.sin_addr, addr_str, sizeof(addr_str) - 1);
int listen_sock = socket(addr_family, SOCK_STREAM, ip_protocol);
if (listen_sock < 0) {
ESP_LOGE(TAG, "Unable to create socket: errno %d", errno);
ESP_LOGI(TAG, "Socket created");
int err = bind(listen_sock, (struct sockaddr *)&destAddr, sizeof(destAddr));
if (err != 0) {
ESP_LOGE(TAG, "Socket unable to bind: errno %d", errno);
ESP_LOGI(TAG, "Socket binded");
err = listen(listen_sock, 1);
if (err != 0) {
ESP_LOGE(TAG, "Error occured during listen: errno %d", errno);
ESP_LOGI(TAG, "Socket listening");
struct sockaddr_in6 sourceAddr; // Large enough for both IPv4 or IPv6
uint addrLen = sizeof(sourceAddr);
int sock = accept(listen_sock, (struct sockaddr *)&sourceAddr, &addrLen);
if (sock < 0) {
ESP_LOGE(TAG, "Unable to accept connection: errno %d", errno);
ESP_LOGI(TAG, "Socket accepted");
while (1) {
int len = recv(sock, rx_buffer, sizeof(rx_buffer) - 1, 0);
// Error occured during receiving
if (len < 0) {
ESP_LOGE(TAG, "recv failed: errno %d", errno);
// Connection closed
else if (len == 0) {
ESP_LOGI(TAG, "Connection closed");
// Data received
else {
// Get the sender's ip address as string
if (sourceAddr.sin6_family == PF_INET) {
inet_ntoa_r(((struct sockaddr_in *)&sourceAddr)->sin_addr.s_addr, addr_str, sizeof(addr_str) - 1);
} else if (sourceAddr.sin6_family == PF_INET6) {
inet6_ntoa_r(sourceAddr.sin6_addr, addr_str, sizeof(addr_str) - 1);
rx_buffer[len] = 0; // Null-terminate whatever we received and treat like a string
//ESP_LOGI(TAG, "Received %d bytes from %s:", len, addr_str);
//ESP_LOGI(TAG, "%s", rx_buffer);
int err = send(sock, rx_buffer, len, 0);
if (err < 0) {
ESP_LOGE(TAG, "Error occured during sending: errno %d", errno);
if (sock != -1) {
ESP_LOGE(TAG, "Shutting down socket and restarting...");
shutdown(sock, 0);
close(sock);
vTaskDelete(NULL);
void app_main()
ESP_ERROR_CHECK( nvs_flash_init() );
initialise_wifi();
wait_for_ip();
xTaskCreate(tcp_server_task, "tcp_server", 4096, NULL, 24, NULL);
Users browsing this forum: Amazon [Bot], PetalBot and 2 guests
