ESP32 sharp dust sensor and wifi?
13ensz
Postby 13ensz » Wed Oct 30, 2019 9:49 pm
Hello Everyone!
I've been struggling for days trying to get both work together however, I've seen online when WIFI is in use only pins 32-36 become available? is this true?
 * Example for using GP2Y1010AU0F Dust Sensor library
 * Created by Mickey Chan
#include <GP2Y1010AU0F.h>
int measurePin = 26;   // Connect dust sensor analog measure pin to esp32 26 pin
int ledPin     = 27;    // Connect dust sensor LED pin to esp32 pin 27
GP2Y1010AU0F dustSensor(ledPin, measurePin); // Construct dust sensor global object
float dustDensity = 0;
  Serial.println(F("GP2Y1010AU0F Dust Sensor Library Example"));
  dustSensor.begin();
  dustDensity = dustSensor.read();
  Serial.print("Dust Density = ");
  Serial.print(dustDensity);
  Serial.println(" ug/m3");
  delay(5000);
WiFive
Re: ESP32 sharp dust sensor and wifi?
Postby WiFive » Thu Oct 31, 2019 2:23 am
Yes, only 32-39 can be used as analog pins with WiFi.
13ensz
Postby 13ensz » Thu Oct 31, 2019 10:20 am
But the dust sensor only works with pins 26/27
Users browsing this forum: Applebot, meta-externalagent and 7 guests
