Unit tests for main app
Arthedian
Postby Arthedian » Thu Oct 31, 2019 7:31 pm
I am using ESP32 with esp-idf. I found out, that there is possible to add unit tests for components. Is it possible to add unit tests for the main app?
dmitrij999
Re: Unit tests for main app
Postby dmitrij999 » Wed Apr 27, 2022 1:59 pm
It's needed for me as well
dmitrij999
Postby dmitrij999 » Sun May 22, 2022 9:08 am
As I understood, the approach putting you logic into one monolite file is NOK, as it becomes hard-to-read.
I propose to divide your code into components, compose Kconfig files for each of components, then your code becomes unit-testable.
P.S. By the way, when I refactored my code and injected unit-tests, I managed to see and solve some unobvious bugs
ashelman-ec
Postby ashelman-ec » Mon May 23, 2022 9:29 am
FYI all,
For anyone looking for details on how to implement unit tests, refer to Espressif's examples / system / unit_test project.
For those using VS Code with the Espressif IDF extension, refer to this post for details on how to run the tests.
tank104
Postby tank104 » Tue Sep 17, 2024 3:10 am
That example doesn't show how to test code in "main" - it doesn't seem possible.
Is it?
Users browsing this forum: Baidu [Spider], PetalBot and 3 guests
