ESP32 RTC GPIO problem
__illia__
Postby __illia__ » Mon Nov 11, 2019 6:01 pm
Hi
I faced a problem with RTC GPIO. As I ran out of normal GPIO's I am trying to use GPIO35 as an output, while normally this is GPI input only pin.
I tried this code:
    rtc_gpio_init(35);
    rtc_gpio_set_direction(35, RTC_GPIO_MODE_OUTPUT_ONLY);
    rtc_gpio_set_level(35, 1);
It is compiled and executed without any errors but pin stays low.
I also tried to add pull up:
    rtc_gpio_pullup_en(35);
but it did not work either.
Also I tried to use number 5 instead of 35 (because GPIO35 is RTC_GPIO5) but then I received errors while calling all described functions, so definetely it's not the root of problem.
Am I missing something? or this pin can't be used as output at all? thanks.
WiFive
Re: ESP32 RTC GPIO problem
Postby WiFive » Tue Nov 12, 2019 2:50 am
Correct
Users browsing this forum: Google [Bot], PerplexityBot and 3 guests
