python 3.8 build error
pacoandres
Postby pacoandres » Sun Nov 24, 2019 7:07 am
Hello.
I'm using the idf on an arch linux computer, and I've installed the python 3.8 update yesterday.
Now the idf can't build projects, it throws an error where generating esp32.project.ld.
The error is:
error while loading shared libraries: libpython3.7m.so.1.0: cannot open shared object file: No such file or directory
make[2]: *** [esp-idf/esp32/CMakeFiles/__ldgen_output_esp32.project.ld.dir/build.make:140: esp-idf/esp32/ld/esp32.project.ld] Error 127
make[1]: *** [CMakeFiles/Makefile2:1997: esp-idf/esp32/CMakeFiles/__ldgen_output_esp32.project.ld.dir/all] Error 2
make: *** [Makefile:130: all] Error 2
make failed with exit code 2
Does anyone have the same error?
Does anyone know how to solve it?
My IDF version is v4.1-dev-281-g96b96ae24-dirty
pacoandres
Re: python 3.8 build error
Postby pacoandres » Mon Nov 25, 2019 8:01 am
I've solved it with the following steps:
  1. Execute the install.sh script in esp home directory
  2. Delete (or rename) the old python env directory
  3. fullclean the project and rebuild it
Users browsing this forum: Baidu [Spider], Bing [Bot], PetalBot and 4 guests
