I am new to esp32 development. Just wondering if there is a function i can use to change the default gateway ip (192.168.4.1) of the ESP32 softAP mode to something else? I only see a way to do this from the Arduino Wifi.h library, i.e. Wifi.softAPConfig(). Is there a native esp-idf function that I can use?
Change ESP32 softAP default IP address
Re: Change ESP32 softAP default IP address
In general, ESP32 Arduino builds on esp-idf, so everything you can do in Arduino, you can somehow do in esp-idf.
In this case, I think you can set the IP with tcpip_adapter_set_ip_info. You probably want to do this before bringing up the SoftAP.
I am also looking for a solution to this problem.
I have tried WiFi.softAPConfig() but could not make it work.
I have tried the tcpip_adapter_set_ip_info() function, it compiles but I get Runtime errors like :-
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:9720
ho 0 tail 12 room 4
load:0x40080400,len:6352
entry 0x400806b8
------ Version : CGMESP_191205
+++++ Enabling WIFI Access Point +++++
E (3065) tcpip_adapter: tcpip_adapter is not initialized!
abort() was called at PC 0x40103a97 on core 1
Backtrace: 0x40091f40:0x3ffcdd30 0x40092171:0x3ffcdd50 0x40103a97:0x3ffcdd70 0x400d17cd:0x3ffcddb0 0x400d961b:0x3ffcdf40 0x4008e689:0x3ffcdf60
Rebooting...
Is it just me or is the esp-idf not well explained ?
ho 0 tail 12 room 4
ho 0 tail 12 room 4
entry 0x400806b8
Rebooting...
Thank you sir. I got it working using esp_netif_set_ip_info().In general, ESP32 Arduino builds on esp-idf, so everything you can do in Arduino, you can somehow do in esp-idf.
esp_netif_init();
esp_netif_t* wifiAP = esp_netif_create_default_wifi_ap();
esp_netif_ip_info_t ip_info;
esp_netif_ip_info_t ipInfo;
IP4_ADDR(&ipInfo.ip, 192,168,2,1);
IP4_ADDR(&ipInfo.gw, 192,168,2,1);
IP4_ADDR(&ipInfo.netmask, 255,255,255,0);
esp_netif_dhcps_stop(wifiAP);
esp_netif_set_ip_info(wifiAP, &ipInfo);
esp_netif_dhcps_start(wifiAP);
ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &wifi_event_handler, NULL));
wifi_config_t wifi_config = {
.ap = {
.ssid = EXAMPLE_ESP_WIFI_SSID,
.ssid_len = strlen(EXAMPLE_ESP_WIFI_SSID),
.password = EXAMPLE_ESP_WIFI_PASS,
.max_connection = EXAMPLE_MAX_STA_CONN,
.authmode = WIFI_AUTH_WPA_WPA2_PSK
if (strlen(EXAMPLE_ESP_WIFI_PASS) == 0) {
wifi_config.ap.authmode = WIFI_AUTH_OPEN;
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &wifi_config));
ESP_ERROR_CHECK(esp_wifi_start());
As usual, I do not understand how this system works.... as I have already stated I am a newbie.
When I enter the above code it says
"CGM_testAP:23:18: error: 'esp_netif_init' was not declared in this scope"
So, a search of all my libraries could Not find any occurance of esp_netif_init().
So how do you get the above code to work ?
Help please.
Help please.
Users browsing this forum: PerplexityBot, Qwantbot and 1 guest
