ESP-NOW speed / out of memory error
benjavita
Postby benjavita » Sun Dec 08, 2019 2:28 pm
I've not been able to find out the speed at which data can be transmitted with ESP-NOW between 2 ESP32 (close to each other), and my tests concluded for a "low" speed under 1Mbps when I would expect much more.
See simplified code below for the transmitter, I'm reading a file on and sending it over using esp_now_send (250 bytes per packet), but if I don't delay enough between each send (around 3ms) I keep getting out of memory errors (ESP_ERR_ESPNOW_NO_MEM).
Is it a limitation in the protocol, or is there something wrong I'm doing?
Maybe there is a better way to transmit the data (this is for live streaming)?
Many thanks :) Ben
#include <WiFi.h>
#include <esp_now.h>
#include <stdint.h>
#include <string.h>
#include <SD.h>
static uint8_t broadcast_mac[] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF };
File file;
typedef struct __attribute__((packed)) esp_now_msg_t
  char data[250];
} esp_now_msg_t;
  network_setup();
  SD.begin();
  file = SD.open("/example.txt");
  static uint32_t counter = 0;
  esp_now_msg_t msg;
 while (file.readBytes(msg.data, 250)) {
    send_msg(&msg);
    delayMicroseconds(3000);
  file.seek(0);
static void send_msg(esp_now_msg_t * msg)
  uint16_t packet_size = sizeof(esp_now_msg_t);
  uint8_t msg_data[packet_size];
  memcpy(&msg_data[0], msg, sizeof(esp_now_msg_t));
  esp_err_t status = esp_now_send(broadcast_mac, msg_data, packet_size);
  if (ESP_OK != status)
    Serial.println("Error sending message");
    handle_error(status);
static void network_setup(void)
  //Puts ESP in STATION MODE
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  if (esp_now_init() != 0)
    return;
  esp_now_peer_info_t peer_info;
  peer_info.channel = WIFI_CHANNEL;
  memcpy(peer_info.peer_addr, broadcast_mac, 6);
  peer_info.ifidx = ESP_IF_WIFI_STA;
  peer_info.encrypt = false;
  esp_err_t status = esp_now_add_peer(&peer_info);
    Serial.println("Could not add peer");
static void handle_error(esp_err_t err)
  switch (err)
    case ESP_ERR_ESPNOW_NOT_INIT:
      Serial.println("Not init");
    case ESP_ERR_ESPNOW_ARG:
      Serial.println("Argument invalid");
    case ESP_ERR_ESPNOW_INTERNAL:
      Serial.println("Internal error");
    case ESP_ERR_ESPNOW_NO_MEM:
      Serial.println("Out of memory");
    case ESP_ERR_ESPNOW_NOT_FOUND:
      Serial.println("Peer is not found");
    case ESP_ERR_ESPNOW_IF:
      Serial.println("Current WiFi interface doesn't match that of peer");
    default:
zhangyanjiao
Re: ESP-NOW speed / out of memory error
Postby zhangyanjiao » Mon Dec 09, 2019 8:14 am
hi benjavita,
The default ESP-NOW bit data is 1Mbps. We are thinking about adding this to the ESP-NOW doc.
As for the memory error, I have tested with the espnow example in IDF, and I have set the send delay time to 1ms in menuconfig, there is no memory error. Can you confirm that the memory error is related to the send delay time?
zhangyanjiao
Postby zhangyanjiao » Wed Mar 25, 2020 12:37 pm
Please refer to this info:
If there is a lot of ESP-NOW data to send, call esp_now_send() to send less than or equal to 250 bytes of data once a time. Note that too short interval between sending two ESP-NOW data may lead to disorder of sending callback function. So, it is recommended that sending the next ESP-NOW data after the sending callback function of the previous sending has returned. The sending callback function runs from a high-priority Wi-Fi task. So, do not do lengthy operations in the callback function. Instead, post the necessary data to a queue and handle it from a lower priority task.
zhangyanjiao
Postby zhangyanjiao » Wed Mar 25, 2020 12:46 pm
hi ,
you can also refer to the ESP-NOW example in IDF:
https://github.com/espressif/esp-idf/bl ... ain.c#L187
Users browsing this forum: ChatGPT-User, Semrush [Bot] and 1 guest
