I2S stream clk change problem
shabtronic
Postby shabtronic » Mon Dec 16, 2019 6:43 pm
Hi All
I have a problem with i2s_stream_set_clk
I have 2 I2S streams - one for playing audio, one for recording from the line-in/mic
When I change the bitrate/samplerate on the play stream and then the rec stream to match - it hangs.
i2s_stream_set_clk(i2s_writer, music_info.sample_rates, music_info.bits, music_info.channels);
i2s_stream_set_clk(i2s_reader, music_info.sample_rates, music_info.bits, music_info.channels);
it hangs in I2S.c, play stream is waiting for RX (which is now tied up with my rec stream).
    // wait all on-going writing finish
if ((p_i2s_obj[i2s_num]->mode & I2S_MODE_TX) && p_i2s_obj[i2s_num]->tx) {
       xSemaphoreTake(p_i2s_obj[i2s_num]->tx->mux, (portTickType)portMAX_DELAY);
if ((p_i2s_obj[i2s_num]->mode & I2S_MODE_RX) && p_i2s_obj[i2s_num]->rx) {
      xSemaphoreTake(p_i2s_obj[i2s_num]->rx->mux, (portTickType)portMAX_DELAY);
I there a easy solution around this?
Currenly I just comment those lines out and it works fine so far, but I know very little about
the internal I2S so, so I'm wondering if that's safe or a terrible hack :P
Shabby
shabtronic
Re: I2S stream clk change problem
Postby shabtronic » Mon Dec 16, 2019 7:09 pm
Actually I was being really dumb there - there's a easy solution to stop the raw I2S rx/tx entanglement:
audio_element_pause(i2s_writer);
audio_element_pause(i2s_reader);
audio_element_resume(i2s_writer,0,0);
audio_element_resume(i2s_reader,0,0);
Works a treat - without having to comment out the I2S.c thread wait code :)
Linc08
Postby Linc08 » Fri Jul 26, 2024 3:19 am
It works for me. Thanks!!
Users browsing this forum: Amazon [Bot] and 0 guests
