ESP32 DevkitC and 433Mhz Radio module not working
Markus
Postby Markus » Wed Dec 18, 2019 8:02 am
Hey people,
I would like to Send and Receive both on One ESP-32DevkitC Board with this Radio modules:
https://cdn-reichelt.de/documents/daten ... _DB_DE.pdf
Does anybody have a simple "Hello Word" project for me?
I started with Library HarwdareSerial.h on Pin 17 for sending and 16 for receiving,
like this project: https://www.youtube.com/watch?v=enS7pxxBJQo
I changed this project to One HardwareSerial object:
#include "HardwareSerial.h"
HardwareSerial MySerial(1);
    MySerial.begin(9600, SERIAL_8N1, 16, 17);
   // Check if loop is working...
    Serial.println("Loop");
   // Transmit the char "h" on PIN 17. This PIN is connected to transmitter module.
    MySerial.print("h");
   // Expect char "h" on PIN 16. This PIN is connected to receiver module.
    while (MySerial.available())
      char c = MySerial.read();
      Serial.print(c);
   delay(1000);
But I only get:
Loop
Loop
Loop
What could be the problem?? :? :? :?
Mark
Re: ESP32 DevkitC and 433Mhz Radio module not working
Postby Sprite » Thu Dec 19, 2019 2:39 am
Moved to the Arduino subforum. And what output would you expect from this code?
Markus
Postby Markus » Thu Dec 19, 2019 9:13 am
I have corrected the line
MySerial.println
to
Serial.println
The chars that I transmit over PIN 17 should be received on PIN 16.
Does anybody has a similar working solution for this "simple" project? I would like to exclude software problems on my side.
Thanks!!
Postby Sprite » Thu Dec 19, 2019 10:38 am
What happens if you remove the serial radio module and short pin 16 and 17?
