i2s_stream.c有需要改进的地方(不判断返回值导致reboot)
Liiidr
Postby Liiidr » Fri Dec 20, 2019 8:46 am
audio_element_handle_t i2s_stream_init(i2s_stream_cfg_t *config);函数在调用i2s_driver_install()时未判断返回值,在i2s驱动安装失败时,后面的程序执行导致reboot!!!!
代码中我自己添加了保护:
//modify by li begin 2019/11/13
if(i2s_driver_install(i2s->config.i2s_port, &i2s->config.i2s_config, 0, NULL) != ESP_OK){
audio_free(i2s);
return NULL;
//modify by li end 2019/11/13[/color]
Code: Untitled.c Select all
audio_element_cfg_t cfg = DEFAULT_AUDIO_ELEMENT_CONFIG();
audio_element_handle_t el;
cfg.open = _i2s_open;
cfg.close = _i2s_close;
cfg.process = _i2s_process;
cfg.destroy = _i2s_destroy;
cfg.task_stack = config->task_stack;
cfg.task_prio = config->task_prio;
cfg.task_core = config->task_core;
cfg.out_rb_size = config->out_rb_size;
cfg.multi_out_rb_num = config->multi_out_num;
cfg.tag = "iis";
cfg.buffer_len = I2S_STREAM_BUF_SIZE;
i2s_stream_t *i2s = audio_calloc(1, sizeof(i2s_stream_t));
AUDIO_MEM_CHECK(TAG, i2s, return NULL);
memcpy(&i2s->config, config, sizeof(i2s_stream_cfg_t));
i2s->type = config->type;
i2s->use_alc = config->use_alc;
i2s->volume = config->volume;
if (config->type == AUDIO_STREAM_READER) {
cfg.read = _i2s_read;
} else if (config->type == AUDIO_STREAM_WRITER) {
cfg.write = _i2s_write;
el = audio_element_init(&cfg);
AUDIO_MEM_CHECK(TAG, el, {
audio_free(i2s);
return NULL;
audio_element_setdata(el, i2s);
audio_element_info_t info;
audio_element_getinfo(el, &info);
info.sample_rates = config->i2s_config.sample_rate;
info.channels = config->i2s_config.channel_format < I2S_CHANNEL_FMT_ONLY_RIGHT ? 2 : 1;
info.bits = config->i2s_config.bits_per_sample;
audio_element_setinfo(el, &info);
[color=#FF0000] //modify by li begin 2019/11/13
audio_free(i2s);
return NULL;
if ((config->i2s_config.mode & I2S_MODE_DAC_BUILT_IN) != 0) {
i2s_set_dac_mode(I2S_DAC_CHANNEL_BOTH_EN);
i2s_pin_config_t i2s_pin_cfg = {0};
get_i2s_pins(i2s->config.i2s_port, &i2s_pin_cfg);
i2s_set_pin(i2s->config.i2s_port, &i2s_pin_cfg);
i2s_mclk_gpio_select(i2s->config.i2s_port, GPIO_NUM_0);
return el;
jason.mao
Re: i2s_stream.c有需要改进的地方(不判断返回值导致reboot)
Postby jason.mao » Fri Dec 20, 2019 12:22 pm
谢谢你的建议
