ESP32-DevKitC with MacOS Sierra - tty port?
mgleason_3
Postby mgleason_3 » Sun Mar 05, 2017 8:28 am
I just received my ESP32-DevKitC and I'm trying to figure out how to communicate with it via my MBP running MacOS Sierra.
I tried comparing the output of ls-al /dev/tty* before and after plugging in the USB cable. Unfortunately, no additional tty port is showing up. I know El Capitan made some changes which blocked the uncertified drivers some of the FTDI chips for the esp8266 dev boards - so I suppose its possible that the DevKitC isn't compatible, though I hope not...
Does anyone know which port I should be looking for?
igrr
Re: ESP32-DevKitC with MacOS Sierra - tty port?
Postby igrr » Sun Mar 05, 2017 10:47 am
Have you installed Silabs VCP driver? DevKitC should show up as /dev/tty.SLAB_USBtoUART.
mgleason_3
Postby mgleason_3 » Sun Mar 05, 2017 6:58 pm
@ESP_igrr
Thanks so much - that was the problem!
For those who follow here's the download location: http://www.silabs.com/products/developm ... cp-drivers
I did search to try to find the solution before posting here.
E.g. Various web sites, read the following (but, unfortunately, none mentioned needing the driver):
Thanks again!
Users browsing this forum: Baidu [Spider], Bytespider, ChatGPT-User, Google [Bot] and 1 guest
