Can't get core dump from flash - Invalid core dump CRC d59a4f1e, should be ffffffff
yurik75
Postby yurik75 » Thu Jan 16, 2020 9:18 am
Hi!
I have ESP32D0WDQ6 on my custom board. IDF v.3.3.1. Host computer with Windows 10.
I modified hello_world example for making abort in task watchdog
and trying to get core dump from flash.
In menuconfig i set options for writing core dump to flash and for abort when
task watchdog timer triggers. I use custom partition table with coredump at 0x110000
(it is default address in espcoredump.py).
In main() i started task with watchdog and then delay for 10000 ms.
Task watchdog triggers, abort() called, dump writed to flash.
When i use espcoredump i see error "Invalid core dump CRC d59a4f1e, should be ffffffff"
hello_world_main.c :
Code: hello_world_main.c Select all
#include <stdio.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_task_wdt.h"
void myRoutine(void *arg)
printf("myRoutine start\n");
esp_task_wdt_add(NULL);
vTaskDelay(10000);
void app_main()
printf("Hello world!\n");
xTaskCreatePinnedToCore(myRoutine, // функция потока
"myRoutine", // текстовая метка
10000, // размер стека в СЛОВАХ (2 байта)
NULL, // входной аргумент
1, // приоритет
NULL, 0); // handle
while(true)
vTaskDelay(100);
esp_task_wdt_reset();
mypartitions.csv :
Code: mypartitions.csv Select all
# Name,   Type, SubType, Offset,  Size, Flags
nvs, data, nvs, 0x9000, 0x5000,
otadata, data, ota, 0xe000, 0x2000,
app0, app, ota_0, 0x10000, 0x100000,
coredump, data, coredump,0x110000, 0x40000,
sdkconfig:
Code: sdkconfig Select all
# Automatically generated file. DO NOT EDIT.
# Espressif IoT Development Framework (ESP-IDF) Project Configuration
CONFIG_IDF_TARGET="esp32"
CONFIG_IDF_FIRMWARE_CHIP_ID=0x0000
# SDK tool configuration
CONFIG_TOOLPREFIX="xtensa-esp32-elf-"
CONFIG_MAKE_WARN_UNDEFINED_VARIABLES=y
CONFIG_APP_COMPILE_TIME_DATE=y
# CONFIG_APP_EXCLUDE_PROJECT_VER_VAR is not set
# CONFIG_APP_EXCLUDE_PROJECT_NAME_VAR is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_NONE is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_ERROR is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_WARN is not set
CONFIG_LOG_BOOTLOADER_LEVEL_INFO=y
# CONFIG_LOG_BOOTLOADER_LEVEL_DEBUG is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_VERBOSE is not set
CONFIG_LOG_BOOTLOADER_LEVEL=3
CONFIG_BOOTLOADER_VDDSDIO_BOOST_1_9V=y
# CONFIG_BOOTLOADER_FACTORY_RESET is not set
# CONFIG_BOOTLOADER_APP_TEST is not set
CONFIG_BOOTLOADER_WDT_ENABLE=y
# CONFIG_BOOTLOADER_WDT_DISABLE_IN_USER_CODE is not set
CONFIG_BOOTLOADER_WDT_TIME_MS=9000
CONFIG_APP_ROLLBACK_ENABLE=y
# CONFIG_APP_ANTI_ROLLBACK is not set
# CONFIG_SECURE_SIGNED_APPS_NO_SECURE_BOOT is not set
# CONFIG_SECURE_BOOT_ENABLED is not set
# CONFIG_FLASH_ENCRYPTION_ENABLED is not set
CONFIG_ESPTOOLPY_BAUD_OTHER_VAL=115200
# CONFIG_FLASHMODE_QIO is not set
# CONFIG_FLASHMODE_QOUT is not set
CONFIG_FLASHMODE_DIO=y
# CONFIG_FLASHMODE_DOUT is not set
CONFIG_ESPTOOLPY_FLASHMODE="dio"
CONFIG_ESPTOOLPY_FLASHFREQ_80M=y
# CONFIG_ESPTOOLPY_FLASHFREQ_40M is not set
# CONFIG_ESPTOOLPY_FLASHFREQ_26M is not set
# CONFIG_ESPTOOLPY_FLASHFREQ_20M is not set
CONFIG_ESPTOOLPY_FLASHFREQ="80m"
# CONFIG_ESPTOOLPY_FLASHSIZE_1MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_2MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE_4MB=y
# CONFIG_ESPTOOLPY_FLASHSIZE_8MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_16MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE="4MB"
CONFIG_ESPTOOLPY_FLASHSIZE_DETECT=y
# CONFIG_ESPTOOLPY_BEFORE_RESET is not set
CONFIG_ESPTOOLPY_BEFORE_NORESET=y
CONFIG_ESPTOOLPY_BEFORE="no_reset"
# CONFIG_ESPTOOLPY_AFTER_RESET is not set
CONFIG_ESPTOOLPY_AFTER_NORESET=y
CONFIG_ESPTOOLPY_AFTER="no_reset"
# CONFIG_MONITOR_BAUD_9600B is not set
# CONFIG_MONITOR_BAUD_57600B is not set
CONFIG_MONITOR_BAUD_115200B=y
# CONFIG_MONITOR_BAUD_230400B is not set
# CONFIG_MONITOR_BAUD_921600B is not set
# CONFIG_MONITOR_BAUD_2MB is not set
# CONFIG_MONITOR_BAUD_OTHER is not set
CONFIG_MONITOR_BAUD_OTHER_VAL=115200
CONFIG_MONITOR_BAUD=115200
# CONFIG_PARTITION_TABLE_SINGLE_APP is not set
# CONFIG_PARTITION_TABLE_TWO_OTA is not set
CONFIG_PARTITION_TABLE_CUSTOM=y
CONFIG_PARTITION_TABLE_CUSTOM_FILENAME="mypartitions.csv"
CONFIG_PARTITION_TABLE_FILENAME="mypartitions.csv"
CONFIG_PARTITION_TABLE_OFFSET=0x8000
CONFIG_PARTITION_TABLE_MD5=y
# CONFIG_OPTIMIZATION_LEVEL_DEBUG is not set
CONFIG_OPTIMIZATION_LEVEL_RELEASE=y
CONFIG_OPTIMIZATION_ASSERTIONS_ENABLED=y
# CONFIG_OPTIMIZATION_ASSERTIONS_SILENT is not set
# CONFIG_OPTIMIZATION_ASSERTIONS_DISABLED is not set
# CONFIG_CXX_EXCEPTIONS is not set
# CONFIG_STACK_CHECK_NONE is not set
CONFIG_STACK_CHECK_NORM=y
# CONFIG_STACK_CHECK_STRONG is not set
# CONFIG_STACK_CHECK_ALL is not set
CONFIG_STACK_CHECK=y
# CONFIG_WARN_WRITE_STRINGS is not set
# CONFIG_DISABLE_GCC8_WARNINGS is not set
# CONFIG_ESP32_APPTRACE_DEST_TRAX is not set
CONFIG_ESP32_APPTRACE_DEST_NONE=y
# CONFIG_ESP32_APPTRACE_ENABLE is not set
CONFIG_ESP32_APPTRACE_LOCK_ENABLE=y
# CONFIG_AWS_IOT_SDK is not set
CONFIG_BT_ENABLED=y
# CONFIG_BTDM_CONTROLLER_MODE_BLE_ONLY is not set
CONFIG_BTDM_CONTROLLER_MODE_BR_EDR_ONLY=y
# CONFIG_BTDM_CONTROLLER_MODE_BTDM is not set
CONFIG_BTDM_CONTROLLER_BR_EDR_MAX_ACL_CONN=2
CONFIG_BTDM_CONTROLLER_BR_EDR_MAX_SYNC_CONN=2
CONFIG_BTDM_CTRL_BR_EDR_SCO_DATA_PATH_EFF=0
CONFIG_BTDM_CONTROLLER_BLE_MAX_CONN_EFF=0
CONFIG_BTDM_CONTROLLER_BR_EDR_MAX_ACL_CONN_EFF=2
CONFIG_BTDM_CONTROLLER_BR_EDR_MAX_SYNC_CONN_EFF=2
CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE_0=y
# CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE_1 is not set
CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE=0
CONFIG_BTDM_CONTROLLER_HCI_MODE_VHCI=y
# CONFIG_BTDM_CONTROLLER_HCI_MODE_UART_H4 is not set
# CONFIG_BTDM_CONTROLLER_MODEM_SLEEP is not set
# CONFIG_BTDM_COEX_BT_OPTIONS is not set
CONFIG_BLUEDROID_ENABLED=y
CONFIG_BLUEDROID_PINNED_TO_CORE_0=y
# CONFIG_BLUEDROID_PINNED_TO_CORE_1 is not set
CONFIG_BLUEDROID_PINNED_TO_CORE=0
CONFIG_BTC_TASK_STACK_SIZE=8196
CONFIG_BTU_TASK_STACK_SIZE=8196
# CONFIG_BLUEDROID_MEM_DEBUG is not set
CONFIG_CLASSIC_BT_ENABLED=y
# CONFIG_A2DP_ENABLE is not set
CONFIG_BT_SPP_ENABLED=y
# CONFIG_HFP_ENABLE is not set
CONFIG_BT_SSP_ENABLED=y
CONFIG_BT_STACK_NO_LOG=y
CONFIG_BT_ACL_CONNECTIONS=2
# CONFIG_BT_ALLOCATION_FROM_SPIRAM_FIRST is not set
CONFIG_BT_BLE_DYNAMIC_ENV_MEMORY=y
# CONFIG_BLE_HOST_QUEUE_CONGESTION_CHECK is not set
CONFIG_SMP_ENABLE=y
CONFIG_BLE_ESTABLISH_LINK_CONNECTION_TIMEOUT=30
CONFIG_BT_RESERVE_DRAM=0xdb5c
# CONFIG_ADC_FORCE_XPD_FSM is not set
CONFIG_ADC2_DISABLE_DAC=y
CONFIG_SPI_MASTER_IN_IRAM=y
CONFIG_SPI_MASTER_ISR_IN_IRAM=y
CONFIG_SPI_SLAVE_IN_IRAM=y
CONFIG_SPI_SLAVE_ISR_IN_IRAM=y
# CONFIG_EFUSE_CUSTOM_TABLE is not set
# CONFIG_EFUSE_VIRTUAL is not set
# CONFIG_EFUSE_CODE_SCHEME_COMPAT_NONE is not set
CONFIG_EFUSE_CODE_SCHEME_COMPAT_3_4=y
# CONFIG_EFUSE_CODE_SCHEME_COMPAT_REPEAT is not set
CONFIG_EFUSE_MAX_BLK_LEN=192
CONFIG_IDF_TARGET_ESP32=y
# CONFIG_ESP32_REV_MIN_0 is not set
CONFIG_ESP32_REV_MIN_1=y
# CONFIG_ESP32_REV_MIN_2 is not set
# CONFIG_ESP32_REV_MIN_3 is not set
CONFIG_ESP32_REV_MIN=1
CONFIG_ESP32_DPORT_WORKAROUND=y
# CONFIG_ESP32_DEFAULT_CPU_FREQ_80 is not set
# CONFIG_ESP32_DEFAULT_CPU_FREQ_160 is not set
CONFIG_ESP32_DEFAULT_CPU_FREQ_240=y
CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ=240
# CONFIG_SPIRAM_SUPPORT is not set
# CONFIG_MEMMAP_TRACEMEM is not set
# CONFIG_MEMMAP_TRACEMEM_TWOBANKS is not set
# CONFIG_ESP32_TRAX is not set
CONFIG_TRACEMEM_RESERVE_DRAM=0x0
# CONFIG_TWO_UNIVERSAL_MAC_ADDRESS is not set
CONFIG_FOUR_UNIVERSAL_MAC_ADDRESS=y
CONFIG_NUMBER_OF_UNIVERSAL_MAC_ADDRESS=4
CONFIG_SYSTEM_EVENT_QUEUE_SIZE=32
CONFIG_SYSTEM_EVENT_TASK_STACK_SIZE=2304
CONFIG_MAIN_TASK_STACK_SIZE=3584
CONFIG_IPC_TASK_STACK_SIZE=1024
CONFIG_TIMER_TASK_STACK_SIZE=3584
# CONFIG_NEWLIB_STDOUT_LINE_ENDING_CRLF is not set
# CONFIG_NEWLIB_STDOUT_LINE_ENDING_LF is not set
CONFIG_NEWLIB_STDOUT_LINE_ENDING_CR=y
# CONFIG_NEWLIB_STDIN_LINE_ENDING_CRLF is not set
# CONFIG_NEWLIB_STDIN_LINE_ENDING_LF is not set
CONFIG_NEWLIB_STDIN_LINE_ENDING_CR=y
# CONFIG_NEWLIB_NANO_FORMAT is not set
CONFIG_CONSOLE_UART_DEFAULT=y
# CONFIG_CONSOLE_UART_CUSTOM is not set
# CONFIG_CONSOLE_UART_NONE is not set
CONFIG_CONSOLE_UART_NUM=0
CONFIG_CONSOLE_UART_BAUDRATE=115200
# CONFIG_ULP_COPROC_ENABLED is not set
CONFIG_ULP_COPROC_RESERVE_MEM=0
# CONFIG_ESP32_PANIC_PRINT_HALT is not set
CONFIG_ESP32_PANIC_PRINT_REBOOT=y
# CONFIG_ESP32_PANIC_SILENT_REBOOT is not set
# CONFIG_ESP32_PANIC_GDBSTUB is not set
CONFIG_ESP32_DEBUG_OCDAWARE=y
# CONFIG_ESP32_DEBUG_STUBS_ENABLE is not set
CONFIG_INT_WDT=y
CONFIG_INT_WDT_TIMEOUT_MS=300
CONFIG_INT_WDT_CHECK_CPU1=y
CONFIG_TASK_WDT=y
CONFIG_TASK_WDT_PANIC=y
CONFIG_TASK_WDT_TIMEOUT_S=5
CONFIG_TASK_WDT_CHECK_IDLE_TASK_CPU0=y
CONFIG_TASK_WDT_CHECK_IDLE_TASK_CPU1=y
CONFIG_BROWNOUT_DET=y
CONFIG_BROWNOUT_DET_LVL_SEL_0=y
# CONFIG_BROWNOUT_DET_LVL_SEL_1 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_2 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_3 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_4 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_5 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_6 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_7 is not set
CONFIG_BROWNOUT_DET_LVL=0
# CONFIG_REDUCE_PHY_TX_POWER is not set
CONFIG_ESP32_TIME_SYSCALL_USE_RTC_FRC1=y
# CONFIG_ESP32_TIME_SYSCALL_USE_RTC is not set
# CONFIG_ESP32_TIME_SYSCALL_USE_FRC1 is not set
# CONFIG_ESP32_TIME_SYSCALL_USE_NONE is not set
CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_RC=y
# CONFIG_ESP32_RTC_CLOCK_SOURCE_EXTERNAL_CRYSTAL is not set
# CONFIG_ESP32_RTC_CLOCK_SOURCE_EXTERNAL_OSC is not set
# CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_8MD256 is not set
CONFIG_ESP32_RTC_CLK_CAL_CYCLES=1024
CONFIG_ESP32_DEEP_SLEEP_WAKEUP_DELAY=2000
CONFIG_ESP32_XTAL_FREQ_40=y
# CONFIG_ESP32_XTAL_FREQ_26 is not set
# CONFIG_ESP32_XTAL_FREQ_AUTO is not set
CONFIG_ESP32_XTAL_FREQ=40
# CONFIG_DISABLE_BASIC_ROM_CONSOLE is not set
# CONFIG_ESP_TIMER_PROFILING is not set
CONFIG_COMPATIBLE_PRE_V2_1_BOOTLOADERS=y
# CONFIG_ESP_ERR_TO_NAME_LOOKUP is not set
CONFIG_ESP32_DPORT_DIS_INTERRUPT_LVL=5
CONFIG_SW_COEXIST_ENABLE=y
CONFIG_SW_COEXIST_PREFERENCE_WIFI=y
# CONFIG_SW_COEXIST_PREFERENCE_BT is not set
# CONFIG_SW_COEXIST_PREFERENCE_BALANCE is not set
CONFIG_SW_COEXIST_PREFERENCE_VALUE=0
CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM=10
CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM=32
# CONFIG_ESP32_WIFI_STATIC_TX_BUFFER is not set
CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER=y
CONFIG_ESP32_WIFI_TX_BUFFER_TYPE=1
CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER_NUM=32
# CONFIG_ESP32_WIFI_CSI_ENABLED is not set
CONFIG_ESP32_WIFI_AMPDU_TX_ENABLED=y
CONFIG_ESP32_WIFI_TX_BA_WIN=6
CONFIG_ESP32_WIFI_AMPDU_RX_ENABLED=y
CONFIG_ESP32_WIFI_RX_BA_WIN=6
CONFIG_ESP32_WIFI_NVS_ENABLED=y
CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_0=y
# CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_1 is not set
CONFIG_ESP32_WIFI_SOFTAP_BEACON_MAX_LEN=752
CONFIG_ESP32_WIFI_MGMT_SBUF_NUM=32
# CONFIG_ESP32_WIFI_DEBUG_LOG_ENABLE is not set
CONFIG_ESP32_WIFI_IRAM_OPT=y
# CONFIG_ESP32_PHY_CALIBRATION_AND_DATA_STORAGE is not set
# CONFIG_ESP32_PHY_INIT_DATA_IN_PARTITION is not set
CONFIG_ESP32_PHY_MAX_WIFI_TX_POWER=20
CONFIG_ESP32_PHY_MAX_TX_POWER=20
# CONFIG_PM_ENABLE is not set
CONFIG_ADC_CAL_EFUSE_TP_ENABLE=y
CONFIG_ADC_CAL_EFUSE_VREF_ENABLE=y
CONFIG_ADC_CAL_LUT_ENABLE=y
# CONFIG_EVENT_LOOP_PROFILING is not set
CONFIG_ESP_HTTP_CLIENT_ENABLE_HTTPS=y
# CONFIG_ESP_HTTP_CLIENT_ENABLE_BASIC_AUTH is not set
CONFIG_HTTPD_MAX_REQ_HDR_LEN=512
CONFIG_HTTPD_MAX_URI_LEN=512
CONFIG_HTTPD_ERR_RESP_NO_DELAY=y
CONFIG_HTTPD_PURGE_BUF_LEN=32
# CONFIG_HTTPD_LOG_PURGE_DATA is not set
# CONFIG_OTA_ALLOW_HTTP is not set
CONFIG_ESP32_ENABLE_COREDUMP_TO_FLASH=y
# CONFIG_ESP32_ENABLE_COREDUMP_TO_UART is not set
# CONFIG_ESP32_ENABLE_COREDUMP_TO_NONE is not set
CONFIG_ESP32_ENABLE_COREDUMP=y
CONFIG_ESP32_CORE_DUMP_MAX_TASKS_NUM=64
CONFIG_DMA_RX_BUF_NUM=10
CONFIG_DMA_TX_BUF_NUM=10
CONFIG_EMAC_L2_TO_L3_RX_BUF_MODE=y
CONFIG_EMAC_CHECK_LINK_PERIOD_MS=2000
CONFIG_EMAC_TASK_PRIORITY=20
CONFIG_EMAC_TASK_STACK_SIZE=3072
# CONFIG_FATFS_CODEPAGE_DYNAMIC is not set
CONFIG_FATFS_CODEPAGE_437=y
# CONFIG_FATFS_CODEPAGE_720 is not set
# CONFIG_FATFS_CODEPAGE_737 is not set
# CONFIG_FATFS_CODEPAGE_771 is not set
# CONFIG_FATFS_CODEPAGE_775 is not set
# CONFIG_FATFS_CODEPAGE_850 is not set
# CONFIG_FATFS_CODEPAGE_852 is not set
# CONFIG_FATFS_CODEPAGE_855 is not set
# CONFIG_FATFS_CODEPAGE_857 is not set
# CONFIG_FATFS_CODEPAGE_860 is not set
# CONFIG_FATFS_CODEPAGE_861 is not set
# CONFIG_FATFS_CODEPAGE_862 is not set
# CONFIG_FATFS_CODEPAGE_863 is not set
# CONFIG_FATFS_CODEPAGE_864 is not set
# CONFIG_FATFS_CODEPAGE_865 is not set
# CONFIG_FATFS_CODEPAGE_866 is not set
# CONFIG_FATFS_CODEPAGE_869 is not set
# CONFIG_FATFS_CODEPAGE_932 is not set
# CONFIG_FATFS_CODEPAGE_936 is not set
# CONFIG_FATFS_CODEPAGE_949 is not set
# CONFIG_FATFS_CODEPAGE_950 is not set
CONFIG_FATFS_CODEPAGE=437
CONFIG_FATFS_LFN_NONE=y
# CONFIG_FATFS_LFN_HEAP is not set
# CONFIG_FATFS_LFN_STACK is not set
CONFIG_FATFS_FS_LOCK=0
CONFIG_FATFS_TIMEOUT_MS=10000
CONFIG_FATFS_PER_FILE_CACHE=y
CONFIG_MB_QUEUE_LENGTH=20
CONFIG_MB_SERIAL_TASK_STACK_SIZE=2048
CONFIG_MB_SERIAL_BUF_SIZE=256
CONFIG_MB_SERIAL_TASK_PRIO=10
# CONFIG_MB_CONTROLLER_SLAVE_ID_SUPPORT is not set
CONFIG_MB_CONTROLLER_NOTIFY_TIMEOUT=20
CONFIG_MB_CONTROLLER_NOTIFY_QUEUE_SIZE=20
CONFIG_MB_CONTROLLER_STACK_SIZE=4096
CONFIG_MB_EVENT_QUEUE_TIMEOUT=20
CONFIG_MB_TIMER_PORT_ENABLED=y
CONFIG_MB_TIMER_GROUP=0
CONFIG_MB_TIMER_INDEX=0
# CONFIG_FREERTOS_UNICORE is not set
CONFIG_FREERTOS_NO_AFFINITY=0x7FFFFFFF
CONFIG_FREERTOS_CORETIMER_0=y
# CONFIG_FREERTOS_CORETIMER_1 is not set
CONFIG_FREERTOS_HZ=1000
CONFIG_FREERTOS_ASSERT_ON_UNTESTED_FUNCTION=y
# CONFIG_FREERTOS_CHECK_STACKOVERFLOW_NONE is not set
# CONFIG_FREERTOS_CHECK_STACKOVERFLOW_PTRVAL is not set
CONFIG_FREERTOS_CHECK_STACKOVERFLOW_CANARY=y
# CONFIG_FREERTOS_WATCHPOINT_END_OF_STACK is not set
CONFIG_FREERTOS_INTERRUPT_BACKTRACE=y
CONFIG_FREERTOS_THREAD_LOCAL_STORAGE_POINTERS=1
CONFIG_FREERTOS_ASSERT_FAIL_ABORT=y
# CONFIG_FREERTOS_ASSERT_FAIL_PRINT_CONTINUE is not set
# CONFIG_FREERTOS_ASSERT_DISABLE is not set
CONFIG_FREERTOS_IDLE_TASK_STACKSIZE=1536
CONFIG_FREERTOS_ISR_STACKSIZE=1536
# CONFIG_FREERTOS_LEGACY_HOOKS is not set
CONFIG_FREERTOS_MAX_TASK_NAME_LEN=16
# CONFIG_SUPPORT_STATIC_ALLOCATION is not set
CONFIG_TIMER_TASK_PRIORITY=1
CONFIG_TIMER_TASK_STACK_DEPTH=2048
CONFIG_TIMER_QUEUE_LENGTH=10
CONFIG_FREERTOS_QUEUE_REGISTRY_SIZE=0
# CONFIG_FREERTOS_USE_TRACE_FACILITY is not set
# CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS is not set
# CONFIG_FREERTOS_DEBUG_INTERNALS is not set
CONFIG_FREERTOS_CHECK_MUTEX_GIVEN_BY_OWNER=y
# CONFIG_FREERTOS_CHECK_PORT_CRITICAL_COMPLIANCE is not set
# CONFIG_HEAP_POISONING_DISABLED is not set
CONFIG_HEAP_POISONING_LIGHT=y
# CONFIG_HEAP_POISONING_COMPREHENSIVE is not set
# CONFIG_HEAP_TRACING is not set
# CONFIG_HEAP_TASK_TRACKING is not set
# CONFIG_LOG_DEFAULT_LEVEL_NONE is not set
# CONFIG_LOG_DEFAULT_LEVEL_ERROR is not set
# CONFIG_LOG_DEFAULT_LEVEL_WARN is not set
CONFIG_LOG_DEFAULT_LEVEL_INFO=y
# CONFIG_LOG_DEFAULT_LEVEL_DEBUG is not set
# CONFIG_LOG_DEFAULT_LEVEL_VERBOSE is not set
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_COLORS=y
# CONFIG_L2_TO_L3_COPY is not set
# CONFIG_LWIP_IRAM_OPTIMIZATION is not set
CONFIG_LWIP_MAX_SOCKETS=10
# CONFIG_USE_ONLY_LWIP_SELECT is not set
CONFIG_LWIP_SO_REUSE=y
CONFIG_LWIP_SO_REUSE_RXTOALL=y
# CONFIG_LWIP_SO_RCVBUF is not set
# CONFIG_LWIP_IP_FRAG is not set
# CONFIG_LWIP_IP_REASSEMBLY is not set
# CONFIG_LWIP_STATS is not set
# CONFIG_LWIP_ETHARP_TRUST_IP_MAC is not set
CONFIG_ESP_GRATUITOUS_ARP=y
CONFIG_GARP_TMR_INTERVAL=60
CONFIG_TCPIP_RECVMBOX_SIZE=32
CONFIG_LWIP_DHCP_DOES_ARP_CHECK=y
# CONFIG_LWIP_DHCP_RESTORE_LAST_IP is not set
CONFIG_LWIP_DHCPS_LEASE_UNIT=60
CONFIG_LWIP_DHCPS_MAX_STATION_NUM=8
# CONFIG_LWIP_AUTOIP is not set
CONFIG_LWIP_NETIF_LOOPBACK=y
CONFIG_LWIP_LOOPBACK_MAX_PBUFS=8
CONFIG_LWIP_MAX_ACTIVE_TCP=16
CONFIG_LWIP_MAX_LISTENING_TCP=16
CONFIG_TCP_MAXRTX=12
CONFIG_TCP_SYNMAXRTX=6
CONFIG_TCP_MSS=1436
CONFIG_TCP_MSL=60000
CONFIG_TCP_SND_BUF_DEFAULT=5744
CONFIG_TCP_WND_DEFAULT=5744
CONFIG_TCP_RECVMBOX_SIZE=6
CONFIG_TCP_QUEUE_OOSEQ=y
# CONFIG_ESP_TCP_KEEP_CONNECTION_WHEN_IP_CHANGES is not set
CONFIG_TCP_OVERSIZE_MSS=y
# CONFIG_TCP_OVERSIZE_QUARTER_MSS is not set
# CONFIG_TCP_OVERSIZE_DISABLE is not set
CONFIG_LWIP_MAX_UDP_PCBS=16
CONFIG_UDP_RECVMBOX_SIZE=6
CONFIG_TCPIP_TASK_STACK_SIZE=3072
CONFIG_TCPIP_TASK_AFFINITY_NO_AFFINITY=y
# CONFIG_TCPIP_TASK_AFFINITY_CPU0 is not set
# CONFIG_TCPIP_TASK_AFFINITY_CPU1 is not set
CONFIG_TCPIP_TASK_AFFINITY=0x7FFFFFFF
# CONFIG_PPP_SUPPORT is not set
# CONFIG_LWIP_MULTICAST_PING is not set
# CONFIG_LWIP_BROADCAST_PING is not set
CONFIG_LWIP_MAX_RAW_PCBS=16
CONFIG_LWIP_DHCP_MAX_NTP_SERVERS=1
CONFIG_LWIP_SNTP_UPDATE_DELAY=3600000
CONFIG_MBEDTLS_INTERNAL_MEM_ALLOC=y
# CONFIG_MBEDTLS_DEFAULT_MEM_ALLOC is not set
# CONFIG_MBEDTLS_CUSTOM_MEM_ALLOC is not set
CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=16384
# CONFIG_MBEDTLS_ASYMMETRIC_CONTENT_LEN is not set
# CONFIG_MBEDTLS_DEBUG is not set
# CONFIG_MBEDTLS_ECP_RESTARTABLE is not set
# CONFIG_MBEDTLS_CMAC_C is not set
CONFIG_MBEDTLS_HARDWARE_AES=y
CONFIG_MBEDTLS_HARDWARE_MPI=y
# CONFIG_MBEDTLS_MPI_USE_INTERRUPT is not set
CONFIG_MBEDTLS_HARDWARE_SHA=y
CONFIG_MBEDTLS_HAVE_TIME=y
CONFIG_MBEDTLS_HAVE_TIME_DATE=y
# CONFIG_MBEDTLS_TLS_SERVER_AND_CLIENT is not set
# CONFIG_MBEDTLS_TLS_SERVER_ONLY is not set
CONFIG_MBEDTLS_TLS_CLIENT_ONLY=y
# CONFIG_MBEDTLS_TLS_DISABLED is not set
CONFIG_MBEDTLS_TLS_CLIENT=y
CONFIG_MBEDTLS_TLS_ENABLED=y
# CONFIG_MBEDTLS_PSK_MODES is not set
CONFIG_MBEDTLS_KEY_EXCHANGE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_RSA=y
CONFIG_MBEDTLS_SSL_RENEGOTIATION=y
# CONFIG_MBEDTLS_SSL_PROTO_SSL3 is not set
CONFIG_MBEDTLS_SSL_PROTO_TLS1=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_1=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y
# CONFIG_MBEDTLS_SSL_PROTO_DTLS is not set
CONFIG_MBEDTLS_SSL_ALPN=y
CONFIG_MBEDTLS_SSL_SESSION_TICKETS=y
CONFIG_MBEDTLS_AES_C=y
# CONFIG_MBEDTLS_CAMELLIA_C is not set
# CONFIG_MBEDTLS_DES_C is not set
CONFIG_MBEDTLS_RC4_DISABLED=y
# CONFIG_MBEDTLS_RC4_ENABLED_NO_DEFAULT is not set
# CONFIG_MBEDTLS_RC4_ENABLED is not set
# CONFIG_MBEDTLS_BLOWFISH_C is not set
# CONFIG_MBEDTLS_XTEA_C is not set
CONFIG_MBEDTLS_CCM_C=y
CONFIG_MBEDTLS_GCM_C=y
# CONFIG_MBEDTLS_RIPEMD160_C is not set
CONFIG_MBEDTLS_PEM_PARSE_C=y
# CONFIG_MBEDTLS_PEM_WRITE_C is not set
CONFIG_MBEDTLS_X509_CRL_PARSE_C=y
CONFIG_MBEDTLS_X509_CSR_PARSE_C=y
# CONFIG_MBEDTLS_ECP_C is not set
CONFIG_MDNS_MAX_SERVICES=10
# CONFIG_MQTT_PROTOCOL_311 is not set
# CONFIG_MQTT_TRANSPORT_SSL is not set
# CONFIG_MQTT_TRANSPORT_WEBSOCKET is not set
# CONFIG_MQTT_USE_CUSTOM_CONFIG is not set
# CONFIG_MQTT_TASK_CORE_SELECTION_ENABLED is not set
# CONFIG_MQTT_CUSTOM_OUTBOX is not set
# CONFIG_OPENSSL_DEBUG is not set
CONFIG_OPENSSL_ASSERT_DO_NOTHING=y
# CONFIG_OPENSSL_ASSERT_EXIT is not set
CONFIG_ESP32_PTHREAD_TASK_PRIO_DEFAULT=5
CONFIG_ESP32_PTHREAD_TASK_STACK_SIZE_DEFAULT=3072
CONFIG_PTHREAD_STACK_MIN=768
CONFIG_ESP32_DEFAULT_PTHREAD_CORE_NO_AFFINITY=y
# CONFIG_ESP32_DEFAULT_PTHREAD_CORE_0 is not set
# CONFIG_ESP32_DEFAULT_PTHREAD_CORE_1 is not set
CONFIG_ESP32_PTHREAD_TASK_CORE_DEFAULT=-1
CONFIG_ESP32_PTHREAD_TASK_NAME_DEFAULT="pthread"
# CONFIG_SPI_FLASH_VERIFY_WRITE is not set
# CONFIG_SPI_FLASH_ENABLE_COUNTERS is not set
CONFIG_SPI_FLASH_ROM_DRIVER_PATCH=y
CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ABORTS=y
# CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_FAILS is not set
# CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ALLOWED is not set
CONFIG_SPI_FLASH_YIELD_DURING_ERASE=y
CONFIG_SPI_FLASH_ERASE_YIELD_DURATION_MS=20
CONFIG_SPI_FLASH_ERASE_YIELD_TICKS=1
CONFIG_SPIFFS_MAX_PARTITIONS=1
CONFIG_SPIFFS_CACHE=y
CONFIG_SPIFFS_CACHE_WR=y
# CONFIG_SPIFFS_CACHE_STATS is not set
# CONFIG_SPIFFS_PAGE_CHECK is not set
CONFIG_SPIFFS_GC_MAX_RUNS=10
# CONFIG_SPIFFS_GC_STATS is not set
CONFIG_SPIFFS_PAGE_SIZE=256
CONFIG_SPIFFS_OBJ_NAME_LEN=32
# CONFIG_SPIFFS_USE_MAGIC is not set
CONFIG_SPIFFS_META_LENGTH=4
# CONFIG_SPIFFS_USE_MTIME is not set
# CONFIG_SPIFFS_DBG is not set
# CONFIG_SPIFFS_API_DBG is not set
# CONFIG_SPIFFS_GC_DBG is not set
# CONFIG_SPIFFS_CACHE_DBG is not set
# CONFIG_SPIFFS_CHECK_DBG is not set
# CONFIG_SPIFFS_TEST_VISUALISATION is not set
CONFIG_IP_LOST_TIMER_INTERVAL=120
CONFIG_TCPIP_LWIP=y
CONFIG_UNITY_ENABLE_FLOAT=y
CONFIG_UNITY_ENABLE_DOUBLE=y
# CONFIG_UNITY_ENABLE_COLOR is not set
CONFIG_UNITY_ENABLE_IDF_TEST_RUNNER=y
# CONFIG_UNITY_ENABLE_FIXTURE is not set
CONFIG_SUPPRESS_SELECT_DEBUG_OUTPUT=y
CONFIG_SUPPORT_TERMIOS=y
# CONFIG_WL_SECTOR_SIZE_512 is not set
CONFIG_WL_SECTOR_SIZE_4096=y
CONFIG_WL_SECTOR_SIZE=4096
CONFIG_WIFI_PROV_SCAN_MAX_ENTRIES=16
Console log:
Code: Untitled.txt Select all
c:\Users\yuri\esp\hello_world>idf.py -p COM3 monitor
Note: You are using Python 3.7.3. Python 3 support is new, please report any problems you encounter. Search for 'Setting the Python Interpreter' in the ESP-IDF docs if you want to use Python 2.7.
Checking Python dependencies...
Python requirements from c:\Zentec\lib\espidf331\requirements.txt are satisfied.
Running idf_monitor in directory c:\Users\yuri\esp\hello_world
Executing "C:\Users\yuri\.espressif\python_env\idf3.3_py3.7_env\Scripts\python.exe c:\Zentec\lib\espidf331\tools/idf_monitor.py -p COM3 -b 115200 c:\Users\yuri\esp\hello_world\build\firmware.elf -m 'C:\Users\yuri\.espressif\python_env\idf3.3_py3.7_env\Scripts\python.exe' 'c:\Zentec\lib\espidf331\tools\idf.py' '-p' 'COM3'"...
--- idf_monitor on COM3 115200 ---
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:6560
ho 0 tail 12 room 4
load:0x40078000,len:11180
load:0x40080400,len:6004
entry 0x40080704
I (66) boot: Chip Revision: 1
I (34) boot: ESP-IDF v3.3.1 2nd stage bootloader
I (34) boot: compile time 11:35:46
I (34) boot: Enabling RNG early entropy source...
I (39) boot: SPI Speed : 80MHz
I (43) boot: SPI Mode : DIO
I (47) boot: SPI Flash Size : 4MB
I (51) boot: Partition Table:
I (54) boot: ## Label Usage Type ST Offset Length
I (62) boot: 0 nvs WiFi data 01 02 00009000 00005000
I (69) boot: 1 otadata OTA data 01 00 0000e000 00002000
I (77) boot: 2 app0 OTA app 00 10 00010000 00100000
I (84) boot: 3 coredump Unknown data 01 03 00110000 00040000
I (91) boot: End of partition table
I (96) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x06114 ( 24852) map
I (112) esp_image: segment 1: paddr=0x0001613c vaddr=0x3ffbdb60 size=0x02550 ( 9552) load
I (116) esp_image: segment 2: paddr=0x00018694 vaddr=0x40080000 size=0x00400 ( 1024) load
0x40080000: _WindowOverflow4 at C:/Zentec/lib/espidf331/components/freertos/xtensa_vectors.S:1779
I (123) esp_image: segment 3: paddr=0x00018a9c vaddr=0x40080400 size=0x07574 ( 30068) load
I (141) esp_image: segment 4: paddr=0x00020018 vaddr=0x400d0018 size=0x13f68 ( 81768) map
0x400d0018: _stext at ??:?
I (164) esp_image: segment 5: paddr=0x00033f88 vaddr=0x40087974 size=0x01da0 ( 7584) load
0x40087974: xPortGetCoreID at C:/Zentec/lib/espidf331/components/freertos/include/freertos/portable.h:210
(inlined by) prvProcessTimerOrBlockTask at C:/Zentec/lib/espidf331/components/freertos/timers.c:589
(inlined by) prvTimerTask at C:/Zentec/lib/espidf331/components/freertos/timers.c:544
I (173) boot: Loaded app from partition at offset 0x10000
I (173) boot: Disabling RNG early entropy source...
I (176) cpu_start: Pro cpu up.
I (180) cpu_start: Application information:
I (184) cpu_start: Project name: esp-idf
I (189) cpu_start: App version: 1
I (194) cpu_start: Compile time: Jan 16 2020 11:35:28
I (200) cpu_start: ELF file SHA256: 3326b1b89c849ed8...
I (206) cpu_start: ESP-IDF: v3.3.1
I (211) cpu_start: Starting app cpu, entry point is 0x40081110
0x40081110: call_start_cpu1 at C:/Zentec/lib/espidf331/components/esp32/cpu_start.c:269
I (0) cpu_start: App cpu up.
I (221) heap_init: Initializing. RAM available for dynamic allocation:
I (228) heap_init: At 3FFAE6E0 len 0000F480 (61 KiB): DRAM
I (235) heap_init: At 3FFC08E8 len 0001F718 (125 KiB): DRAM
I (240) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (247) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (256) heap_init: At 40089714 len 000168EC (90 KiB): IRAM
I (259) cpu_start: Pro cpu start user code
I (53) esp_core_dump_flash: Init core dump to flash
I (53) esp_core_dump_flash: Found partition 'coredump' @ 110000 262144 bytes
I (0) cpu_start: Starting scheduler on APP CPU..check failed: 0xffffffff -> 0xd59a4f1e!
E (10084) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (10084) task_wdt: - myRoutine (CPU 0)
E (10084) task_wdt: Tasks currently running:
E (10084) task_wdt: CPU 0: IDLE0
E (10084) task_wdt: CPU 1: IDLE1
E (10084) task_wdt: Aborting.
abort() was called at PC 0x400d16fc on core 0
0x400d16fc: task_wdt_isr at C:/Zentec/lib/espidf331/components/esp32/task_wdt.c:252
ELF file SHA256: 3326b1b89c849ed8ee164a8d582122e3bbddf565178d0384b46bd0b880d0412e
Backtrace: 0x40088f87:0x3ffbe1e0 0x40089245:0x3ffbe200 0x400d16fc:0x3ffbe220 0x40082841:0x3ffbe240 0x400e3ea3:0x3ffb2830 0x400d1c93:0x3ffb2850 0x40086f69:0x3ffb2870
0x40088f87: invoke_abort at C:/Zentec/lib/espidf331/components/esp32/panic.c:715
0x40089245: abort at C:/Zentec/lib/espidf331/components/esp32/panic.c:715
0x40082841: _xt_lowint1 at C:/Zentec/lib/espidf331/components/freertos/xtensa_vectors.S:1154
0x400e3ea3: esp_pm_impl_waiti at C:/Zentec/lib/espidf331/components/esp32/pm_esp32.c:492
0x400d1c93: esp_vApplicationIdleHook at C:/Zentec/lib/espidf331/components/esp32/freertos_hooks.c:86
0x40086f69: prvIdleTask at C:/Zentec/lib/espidf331/components/freertos/tasks.c:5063
I (5124) esp_core_dump_flash: Save core dump to flash...
I (5129) esp_core_dump_common: Found tasks: (8)!
E (5240) esp_core_dump_common: Skipped 1 tasks with bad TCB!
I (5240) esp_core_dump_flash: Core dump has been saved to flash.
Rebooting...
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
I (85) boot: 3 coredump Unknown data 01 03 00110000 00040000
I (92) boot: End of partition table
I (117) esp_image: segment 2: paddr=0x00018694 vaddr=0x40080000 size=0x00400 ( 1024) load
I (142) esp_image: segment 4: paddr=0x00020018 vaddr=0x400d0018 size=0x13f68 ( 81768) map
I (165) esp_image: segment 5: paddr=0x00033f88 vaddr=0x40087974 size=0x01da0 ( 7584) load
I (174) boot: Loaded app from partition at offset 0x10000
I (174) boot: Disabling RNG early entropy source...
I (185) cpu_start: Project name: esp-idf
I (190) cpu_start: App version: 1
I (201) cpu_start: App cpu up.
I (222) heap_init: Initializing. RAM available for dynamic allocation:
I (229) heap_init: At 3FFAE6E0 len 0000F480 (61 KiB): DRAM
I (241) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (260) cpu_start: Pro cpu start user code
I (54) esp_core_dump_flash: Init core dump to flash
I (54) esp_core_dump_flash: Found partition 'coredump' @ 110000 262144 bytes
E (10085) task_wdt: CPU 1: IDLE1tly running:red. The following tasks did not reset the watchdog in time:
E (10085) task_wdt: Aborting.
I (5130) esp_core_dump_common: Found tasks: (8)!
E (5249) esp_core_dump_common: Skipped 1 tasks with bad TCB!
load:0x40078000,len:11180_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
entry 0x40080704
I (67) boot: Chip Revision: 1
I (55) boot: ## Label Usage Type ST Offset Length
I (70) boot: 1 otadata OTA data 01 00 0000e000 00002000
E (5225) esp_core_dump_common: Skipped 1 tasks with bad TCB!
I (5225) esp_core_dump_flash: Core dump has been saved to flash.
Rebooting...
ho 0 tail 12 room 4
entry 0x40080704
I (92) boot: End of partition tableknown data 01 03 00110000 00040000
myRoutine start
c:\Users\yuri\esp\hello_world>c:\Zentec\lib\espidf331\components\espcoredump\espcoredump.py -p COM3 info_corefile build\firmware.elf
espcoredump.py v0.3-dev
esptool.py v2.8
Serial port COM3
Connecting........_____.
Chip is ESP32D0WDQ6 (revision 1)
Crystal is 40MHz
MAC: 30:ae:a4:f7:a5:34
Uploading stub...
Running stub...
Stub running...
4 (100 %)
4 (100 %)
Read 4 bytes at 0x110000 in 0.1 seconds (0.4 kbit/s)...
Hard resetting via RTS pin...
esptool.py v2.8
Serial port COM3
Connecting........_
Crystal is 40MHz
Uploading stub...
Running stub...
Stub running...
5668 (100 %)
5668 (100 %)
Read 5668 bytes at 0x110000 in 0.5 seconds (85.3 kbit/s)...
A fatal error occurred: Invalid core dump CRC d59a4f1e, should be ffffffff
Thanks for any help!!!
yurik75
Postby yurik75 » Wed Jan 22, 2020 2:17 pm
I opened issue #4656 on github
