JTAG debugging is not working: Error: esp32.cpu0: IR capture error; saw 0x1f not 0x01
Posted: Thu Jan 30, 2020 10:42 pm
Hello guys,
I totally do not get it. So I have been using the blink example as a starter to program the ESP32WROVER-B (ESP-WROVER-KitV4.1) module. All the JTAG jumpers are correctly set, also the udev rules within my Ubuntu 19.10 machine.
I can successfully compile and flash the bare "blink" example (). JTAG debugging is also working using . As soon as I extend the code base for a minimum debugging is not working any more. I get the following error:
Can anybody tell me why? Because it compile correctly and the monitor output is also correct. Thus, the app works like charm. But I cannot debug it via JTAG
main.c
Actually I just added the nvs part. Does anybody can get it to work?
idf.py -p /dev/ttyUSB1 cleanfull build flash monitorCode: Select all
openocd -f board/esp32-wrover-kit-3.3v.cfgCode: Select all
$ openocd -f board/esp32-wrover-kit-3.3v.cfg
Open On-Chip Debugger v0.10.0-esp32-20191114 (2019-11-14-14:15)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
Info : Configured 2 cores
Error: type 'esp32' is missing virt2phys
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : Listening on port 3333 for gdb connectionsmain.c
// FreeRTOS includes
#include "freertos/task.h"
// ESP32 settings
#include "nvs_flash.h"
// Error/debugging library
#include "esp_err.h"
#define LOG_LOCAL_LEVEL ESP_LOG_VERBOSE
#include "esp_log.h"
// Driver
#include "driver/gpio.h"
// Global definitions and variables
static const char* Log_Tag = "main";
#define BLINK_GPIO 14
// Initialize nonvolatile storage
esp_err_t nvs_init(void)
esp_err_t ret = nvs_flash_init();
if (ret == ESP_ERR_NVS_NO_FREE_PAGES)
ESP_ERROR_CHECK(nvs_flash_erase());
return ret;
// Actual task
void blink_task(void *pvParameter)
/* Configure the IOMUX register for pad BLINK_GPIO (some pads are
muxed to GPIO on reset already, but some default to other
functions and need to be switched to GPIO. Consult the
Technical Reference for a list of pads and their default
functions.) => make BLINK_GPIO as IO pin.
gpio_pad_select_gpio(BLINK_GPIO);
// Set the GPIO as a push/pull output
gpio_set_direction(BLINK_GPIO, GPIO_MODE_OUTPUT);
while (1)
vTaskDelay(500 / portTICK_RATE_MS);
ESP_LOGD(Log_Tag, "Blink");
void app_main()
// Init parts on PCB
ESP_ERROR_CHECK(nvs_init());
// attach blink_task to a CPU core.
xTaskCreate(&blink_task, "blink_task", configMINIMAL_STACK_SIZE, NULL, 5, NULL);
