How to disable JTAG?
MalteJ
Postby MalteJ » Fri Mar 10, 2017 12:59 pm
I want to use the JTAG pins as GPIOs.
How can I disable JTAG? Is this permanent or is it possible to reenable JTAG afterwards?
Thank you!
Best,
Malte
MalteJ
Re: How to disable JTAG?
Postby MalteJ » Sat Mar 11, 2017 2:35 pm
It looks like you can only disable JTAG while enabling Secure Boot, right?
WiFive
Postby WiFive » Sat Mar 11, 2017 7:50 pm
What is the conflict you are having?
Postby Sprite » Sun Mar 12, 2017 5:14 am
From memory, the JTAG pins are routed to the GPIOs by either the IO mux or the GPIO matrix, I don't remember which one off the top of my head. By simply reconfiguring the values in the configuration registers of that (or using an esp-idf driver, which will do this for you) you can deselect the JTAG function and use the GPIO for something else; no need to mess with fuses.
Users browsing this forum: Qwantbot, Semrush [Bot] and 2 guests
