I have a question ESP32 WROOM 32D. After the first run, a message is sent, which I attach without loading the program into the chip. The ESP32 Wroom 32D starts with SoftAP named ESP_xxxxx. IP 192.168.4.1 and can be connected via Wifi. After the serial channel can not record the program as with ESP32 WROOM32 there is OK.
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:5656
load:0x40078000,len:0
ho 12 tail 0 room 4
load:0x40078000,len:13844
entry 0x40078fc4
[0;32mI (31) boot: ESP-IDF v3.0.7 2nd stage bootloader[0m
[0;32mI (31) boot: compile time 09:04:31[0m
[0;32mI (31) boot: Enabling RNG early entropy source...[0m
[0;32mI (35) boot: SPI Speed : 40MHz[0m
[0;32mI (39) boot: SPI Mode : DIO[0m
[0;32mI (43) boot: SPI Flash Size : 4MB[0m
[0;32mI (47) boot: Partition Table:[0m
[0;32mI (51) boot: ## Label Usage Type ST Offset Length[0m
[0;32mI (58) boot: 0 phy_init RF data 01 01 0000f000 00001000[0m
[0;32mI (66) boot: 1 otadata OTA data 01 00 00010000 00002000[0m
[0;32mI (73) boot: 2 nvs WiFi data 01 02 00012000 0000e000[0m
[0;32mI (81) boot: 3 at_customize unknown 40 00 00020000 000e0000[0m
[0;32mI (88) boot: 4 ota_0 OTA app 00 10 00100000 00180000[0m
[0;32mI (96) boot: 5 ota_1 OTA app 00 11 00280000 00180000[0m
[0;32mI (103) boot: End of partition table[0m
[0;32mI (107) boot: No factory image, trying OTA 0[0m
[0;32mI (112) esp_image: segment 0: paddr=0x00100020 vaddr=0x3f400020 size=0x20614 (132628) map[0m
[0;32mI (168) esp_image: segment 1: paddr=0x0012063c vaddr=0x3ffc0000 size=0x02d7c ( 11644) load[0m
[0;32mI (173) esp_image: segment 2: paddr=0x001233c0 vaddr=0x40080000 size=0x00400 ( 1024) load[0m
[0;32mI (175) esp_image: segment 3: paddr=0x001237c8 vaddr=0x40080400 size=0x0c848 ( 51272) load[0m
[0;32mI (205) esp_image: segment 4: paddr=0x00130018 vaddr=0x400d0018 size=0xdfc80 (916608) map[0m
[0;32mI (526) esp_image: segment 5: paddr=0x0020fca0 vaddr=0x4008cc48 size=0x02504 ( 9476) load[0m
[0;32mI (530) esp_image: segment 6: paddr=0x002121ac vaddr=0x400c0000 size=0x00064 ( 100) load[0m
[0;32mI (542) boot: Loaded app from partition at offset 0x100000[0m
[0;32mI (542) boot: Disabling RNG early entropy source...[0m
1.1.3
I (596) wifi: wifi firmware version: 703e53b
I (596) wifi: config NVS flash: enabled
I (596) wifi: config nano formating: disabled
I (607) wifi: Init dynamic tx buffer num: 32
I (607) wifi: Init data frame dynamic rx buffer num: 32
I (607) wifi: Init management frame dynamic rx buffer num: 32
I (612) wifi: wifi driver task: 3ffdeeb8, prio:23, stack:3584
I (618) wifi: Init static rx buffer num: 10
I (621) wifi: Init dynamic rx buffer num: 32
I (626) wifi: wifi power manager task: 0x3ffe369c prio: 21 stack: 2560
I (658) wifi: mode : softAP (84:0d:8e:e1:2a:79)
I (666) wifi: mode : sta (84:0d:8e:e1:2a:78) + softAP (84:0d:8e:e1:2a:79)
I (669) wifi: mode : softAP (84:0d:8e:e1:2a:79)
I (674) wifi: set country: cc=CN
ESP32 WROOM 32D boot program
