I run the LED_PWM as an Sound output.
Due the noise I want to disable the Output, if I don't play any sound. How can I disable it?
REG_CLR_BIT(GPIO_PIN_MUX_REG[18], SLP_OE);
or this
gpio_set_direction(LS_IO, GPIO_MODE_INPUT);
doesn't work. I'm still able to play a sound via PWM.
Can anybody help me with this issue?
kind regards
Peter
Disable GPIO
Re: Disable GPIO
You can probably use the GPIO mux to mux the output pin back to the GPIO, or to a fixed 1 or 0 signal. Use gpio_matrix_out(ii_pin_number, SIG_GPIO_OUT_IDX, false, false); for example.
Re: Disable GPIO
I have have tried to MUX it to a fix value. Unfortunately there is still noise on the output. (If I don't initialize the PWM there is no noise.)
Is there no way to deinitialize the Pin in a fast way?
Regards
Peter
Regards
Peter
Re: Disable GPIO
Can you specify 'noise'? Is the PWM signal still available on the GPIO? Because with the GPIO muxed to something else, that should not happen.
Re: Disable GPIO
thanks for the fast reply. If I change the PIN Mux the PWM disappear, but I still have some random noise on the pin. I try to get a closer look with a oscilloscope on the pin.
Kind regards
Peter
Kind regards
Peter
