Hello -
I was reading the technical reference manual for the ESP32-S2, and noticed it refers to download boot mode via USB. Does this mean it's possible to load code onto a blank ESP32-S2 via USB?
Thanks,
Tim
ESP32-S2: USB bootloader?
Re: ESP32-S2: USB bootloader?
Hi Tim,
That's correct. The ESP32-S2 has a standard DFU bootloader and also can support the existing serial loader protocol over USB/serial (CDC device).
Angus
Angus
SomeCallMeTim
Hi Angus -
That's great news! (In addition to the reference manual, I was speculating that CDC-ACM and DFU might've been in there based on the *_descriptors symbols exported.) Looking forward to trying out the ESP32-S2 at some point.
I looked around a bit in the esp-idf, and I didn't see any USB support yet in the SDK. Do you know the rough timeline for support? E.g. Along the lines of in a few weeks, a few months, or later this year?
Or can you invoke the ROM functions for this and get some CDC-ACM support? I see lots of USB related symbols inside the esp32s2.rom.ld file, although nothing inside the SDK invokes these yet. (Looking at the Uart_Init_USB function and its self documentation.)
Sounds like it might be the "Designware Controller" USB OTG IP based on the register names, and the symbols usb_dc_* within the bootloader's ROM code?
Thanks,
Tim
Thanks,
Tim
The S2 ROM emulates a CDC-ACM, and there are hooks in the ROM code to allow use in ESP-IDF as well. On top of that, we are also going to add the TinyUSB stack to ESP-IDF, which supports a fair amount of standard USB interfaces plus the option to add your own. The controller indeed is a Designware one.
