Getting the uptime
StefanRvO
Getting the uptime
Postby StefanRvO » Thu Mar 16, 2017 8:39 pm
Hi
Is it possible to find the time since last boot?
I know that it is possible to use gettimeofday() in some cases, but this (obviously) does not work if sntp is enabled. Is there any other way to find the uptime?
Regards
Stefan
Hans Dorn
Re: Getting the uptime
Postby Hans Dorn » Thu Mar 16, 2017 8:55 pm
Hi
xTaskGetTickCount will probably do the trick.
P.S: The tickcount will wrap every 49 days I guess. You'll have to check it periodically and adjust your uptime calculation.
meowsqueak
Postby meowsqueak » Wed Mar 14, 2018 5:08 am
With a default tick rate of 100 Hz and TickType_t being a uint32_t, wouldn't it overflow every ~497 days?
In [7]: 2**32 / 100 / 60 / 60 / 24.
Out[7]: 497.10269629629624
igrr
Postby igrr » Wed Mar 14, 2018 5:50 am
esp_timer_get_time returns 64-bit time since startup, in microseconds.
meowsqueak
Postby meowsqueak » Wed Mar 14, 2018 6:25 am
Oh, now that IS useful! - now I wish I hadn't just spent the last hour implementing the exact same thing :)
By my calculations that should last for about 584,000 years before overflow. Should be sufficient for most IoT applications.
EDIT: oh, it's signed, so I guess that's only 292,000 years then. Pity.
shelladdicted
Postby shelladdicted » Fri Jun 08, 2018 4:21 pm
esp_timer_get_time() returns an int64_t so [-2³²,+2³²] is the max.
in a day there are 8.64*10^10 uS and is bigger than 2³² so esp_timer_get_time() will overflow in less than one day
how can i handle more than one day?
Postby Sprite » Sat Jun 09, 2018 4:52 am
Let me correct you there: esp_timer_get_time() returns an int64_t so [-2^63,+2^63-1] is the max.
meowsqueak
Postby meowsqueak » Sat Jun 09, 2018 7:24 am
As ESP_Sprite said, you've got your math wrong. It will overflow after 292,000 years. Should be long enough for most IoT apps and even some enterprise applications.
HermannSW
Contact:
Postby HermannSW » Wed Nov 14, 2018 9:04 am
Interesting. I looked into ESP32 (and ESP8266) overflow for MicroPython utime module ticks_ms() and ticks_us() functions:
https://forum.micropython.org/viewtopic ... 855#p31855
Both do return uint32_t, so overflow after 71 minutes / 49 days.
Interestingly ESP8266 MicroPython implements high 32bit of 64bit counter and allows for same overflows, although ESP8266 system_get_time() returns uint32_t only.
Ritesh
Contact:
Postby Ritesh » Mon Nov 19, 2018 7:35 pm
From which ESP32 IDF, It has been supported?
Regards,
Ritesh Prajapati
Users browsing this forum: Baidu [Spider], Google [Bot] and 1 guest
