Windows Powershell to build, configure, flash etc.
Zeni241
Postby Zeni241 » Wed Mar 11, 2020 3:25 pm
Currently I am using ESP-IDF command prompt to build, configure, flash etc. How can I use windows Powershell to run commands like idf.py menuconfig etc.?
I am using idf version 4.0 with CMake.
AndreiGramakov
Contact:
Re: Windows Powershell to build, configure, flash etc.
Postby AndreiGramakov » Fri Apr 03, 2020 8:39 am
Hi!
While you are using 4.0 which has no pwsh support (I recommend to update, really) probably the simplest solution would be make it in the Inception style. in PowerShell go to your IDF directory and run
only once
cmd /c install.bat
and then
cmd /c "export.bat && powershell"
if you have IDF_PATH in your environment
you can write from any directory
cmd /c "$env:IDF_PATH\export.bat && PowerShell"
and right after start to use idf.py
See more here:
https://docs.espressif.com/projects/esp ... x.html#id4
and here:
Embedded Sofware Engineer @ Espressif Systems
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot] and 2 guests
