ADF version :V3.3.1
1,
compile and download the example, appear logs as fllow:
I (75) boot: Chip Revision: 1
I (75) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (41) boot: ESP-IDF v3.3.1 2nd stage bootloader
I (41) boot: compile time 14:21:23
I (41) boot: Enabling RNG early entropy source...
I (46) boot: SPI Speed : 40MHz
I (50) boot: SPI Mode : DIO
I (54) boot: SPI Flash Size : 4MB
I (58) boot: Partition Table:
I (62) boot: ## Label Usage Type ST Offset Length
I (69) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (77) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (84) boot: 2 factory factory app 00 00 00010000 00300000
I (92) boot: End of partition table
I (96) boot_comm: chip revision: 1, min. application chip revision: 0
I (103) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x883ec (558060) map
I (308) esp_image: segment 1: paddr=0x00098414 vaddr=0x3ffb0000 size=0x033a0 ( 13216) load
I (313) esp_image: segment 2: paddr=0x0009b7bc vaddr=0x40080000 size=0x00400 ( 1024) load
I (315) esp_image: segment 3: paddr=0x0009bbc4 vaddr=0x40080400 size=0x0444c ( 17484) load
I (331) esp_image: segment 4: paddr=0x000a0018 vaddr=0x400d0018 size=0xb43c0 (738240) map
I (591) esp_image: segment 5: paddr=0x001543e0 vaddr=0x4008484c size=0x12d58 ( 77144) load
I (637) boot: Loaded app from partition at offset 0x10000
I (637) boot: Disabling RNG early entropy source...
I (638) psram: This chip is ESP32-D0WD
E (644) spiram: Expected 4096KiB chip but found 8192KiB chip. Bailing out..
E (650) cpu_start: Failed to init external RAM!
abort() was called at PC 0x40081589 on core 0
2,
change "CONFIG_SPIRAM_TYPE_AUTO=y" in menuconfig ,
solve the problem,but reboot continuously and appear log:
I (185) wifi: wifi driver task: 3ffc8c38, prio:23, stack:3584, core=0
I (185) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (193) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
assertion "offset == dataSize" failed: file "D:/Users/cary.liurk/AppData/Roaming/SPB_Data/esp/esp-idf/components/nvs_flash/src/nvs_storage.cpp", line 438, function: esp_err_t nvs::Storage::readMultiPageBlob(uint8_t, const char*, void*, size_t)
abort() was called at PC 0x400d458f on core 0
why?
