only three slave can be attached in SPI ?
chopin1998
Postby chopin1998 » Tue Mar 21, 2017 3:01 am
i have layouted a PCB, esp32 connect 5 spi slave, share same CLK/ MISO/ MOSI and 5 independent nCS to every device.
but when I use spi_bus_add_device() 5 times, it said:
E (199) spi_master: spi_bus_add_device(326): no free cs pins for host
how can I use 5(or more) spi slave device?
chopin1998
Re: only three slave can be attached in SPI ?
Postby chopin1998 » Tue Mar 21, 2017 3:08 am
maybe i call spi_bus_add_device once, with a dummy CS pin number, and select CS via GPIO manually?
why the API has this limit?
Postby Sprite » Tue Mar 21, 2017 6:47 am
Because the hardware only supports three SPI slaves. In theory, the driver could be expanded to allow for an infinite amount of software CS pins (which would have less strictly defined timings, however), but at the moment no one wrote any code for this yet.
loboris
Postby loboris » Tue Mar 21, 2017 8:26 am
You can set the divice configuration not to use CS (spics_io_num = -1) in spi_device_interface_config_t structure
int spics_io_num;               ///< CS GPIO pin for this device, or -1 if not used
and then activate/deactivate CS pip manually.
chopin1998
Postby chopin1998 » Tue Mar 21, 2017 9:01 am
yeah, i did this and use .pre_cb and .post_cb to tgl CS pin
thank you!
chopin1998
Postby chopin1998 » Wed Mar 22, 2017 6:53 am
Ooops....
I can set spics_io_num = -1, but when I call spi_bus_add_device > 3 times, driver still said
loboris
Postby loboris » Wed Mar 22, 2017 8:27 am
Ooops....
If you wan to use more than 3 devices, you have to modify spi_bus_add_device() function, something like this:
#define NO_CS  3				// Number of CS pins per SPI host
// ##### ADDED ----------------------------------------------------------
#define NO_DEV 6				// Number of allowed spi devices per SPI host
static esp_err_t spi_bus_add_device(spi_host_device_t host, spi_device_interface_config_t *dev_config, spi_bus_config_t *bus_config, spi_device_handle_t *handle)
    int freecs, maxdev;
    SPI_CHECK(host>=SPI_HOST && host<=VSPI_HOST, "invalid host", ESP_ERR_INVALID_ARG);
    SPI_CHECK(spihost[host]!=NULL, "host not initialized", ESP_ERR_INVALID_STATE);
    //##### CHANGED --------------------------------------------------------------------------------------------
    if (dev_config->spics_io_num >= 0) {
		SPI_CHECK(GPIO_IS_VALID_OUTPUT_GPIO(dev_config->spics_io_num), "spics pin invalid", ESP_ERR_INVALID_ARG);
    SPI_CHECK(dev_config->clock_speed_hz > 0, "invalid sclk speed", ESP_ERR_INVALID_ARG);
    if (dev_config->spics_io_num > 0) maxdev=NO_CS;
    else maxdev=NO_DEV;
    for (freecs=0; freecs<maxdev; freecs++) {
        //See if this slot is free; reserve if it is by putting a dummy pointer in the slot.
        //We use an atomic compare&swap to make this thread-safe.
        if (__sync_bool_compare_and_swap(&spihost[host]->device[freecs], NULL, (spi_device_t *)1)) break;
    SPI_CHECK(freecs!=maxdev, "no free devices for host", ESP_ERR_NOT_FOUND);
    //The hardware looks like it would support this, but actually setting cs_ena_pretrans when transferring in full
    //duplex mode does absolutely nothing on the ESP32.
    SPI_CHECK(dev_config->cs_ena_pretrans==0 || (dev_config->flags & SPI_DEVICE_HALFDUPLEX), "cs pretrans delay incompatible with full-duplex", ESP_ERR_INVALID_ARG);
chopin1998
Postby chopin1998 » Thu Mar 23, 2017 3:58 am
Ooops....
    int freecs, maxdev;
    else maxdev=NO_DEV;
yes, I have change #define NO_DEV 5.
thank you!
SinglWolf
Postby SinglWolf » Sat Dec 14, 2019 2:44 pm
Hello!
I have the same problem. I am using framework-espidf 3.30300.190916 (3.3.0) and the proposed fixes cannot be applied in any way.
When using espressif-arduino-esp32, 4 SPI devices (tft display, (VS1053 uses 2 bus) and touchscreen) work normally.
Please, help.
Users browsing this forum: Google [Bot], YisouSpider and 2 guests
