SOLVED: ESP32 esp-now data transfer is pausing
newtwoarduino
Postby newtwoarduino » Thu Apr 02, 2020 3:30 pm
I am working with esp-now. I simply want a nonstop continuous stream of bytes being transferred from one esp32 to another. For my test, I am trying to send a 1 and then a 0, and repeating.
When I monitor the receiver, it appears to receive these bytes as intended, but then pauses for a moment, then continues to receive as intended, then pauses again... repeating.
I put together the code below from snippets of online tutorials.
What can I change in the code to make the stream non-stop? Or should I use a different method than esp-now?
Thank you for your assistance.
SENDER
#include <esp_now.h>
#include <WiFi.h>
uint8_t broadcastAddress[] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
uint8_t data = 0;
  WiFi.mode(WIFI_STA);
  if (esp_now_init() != ESP_OK) {
    return;
  // Register peer
  esp_now_peer_info_t peerInfo;
  memcpy(peerInfo.peer_addr, broadcastAddress, 6);
  peerInfo.channel = 0;
  peerInfo.encrypt = false;
  // Add peer
  if (esp_now_add_peer(&peerInfo) != ESP_OK) {
    Serial.println("Failed to add peer");
    return;
  data++;
  esp_now_send(broadcastAddress, &data, 1);
  data--;
RECEIVER
#include <WiFi.h>
uint8_t data;
void OnDataRecv(const uint8_t * mac, const uint8_t *incomingData, int len) {
  memcpy(&data, incomingData, 1);
    return;
  esp_now_register_recv_cb(OnDataRecv);
  Serial.println(data);
mattlogue
Re: ESP32 esp-now data transfer is pausing
Postby mattlogue » Fri Apr 03, 2020 3:17 pm
Sorry not answering. I am plagued by same symptoms, not impressed with esp now, won't reach me from garage, yet I see tons of other APs. May just chain together in WiFi and use UDP.
newtwoarduino
Postby newtwoarduino » Fri Apr 03, 2020 5:57 pm
No worries.
I have been doing more experimentation today... It appears the pause only happens when sending to the serial monitor.
When I remove that from the equation, the data stream is indeed constant from one esp32 to the other.
