Can't disable Timer interrupt
francis2
Postby francis2 » Fri Apr 10, 2020 1:04 am
Hey,
So I followed the implementation of timer interrupt (https://github.com/espressif/esp-idf/bl ... ple_main.c ). It worked perfectly but now I want to disable and then re enable the interuption caused by Group 0 Timer 1 's alarm, and I can't seem to disable the interrupt.
This is the timer's config and init
Code: Untitled.c Select all
void timerGrp0Init(int timer_idx, double timer_interval_sec){
/* Select and initialize basic parameters of the timer */
timer_config_t config;
config.divider = TIMER_DIVIDER;
config.counter_dir = TIMER_COUNT_UP;
config.counter_en = TIMER_PAUSE;
config.alarm_en = TIMER_ALARM_EN;
config.intr_type = TIMER_INTR_LEVEL;
config.auto_reload = 1;
#ifdef TIMER_GROUP_SUPPORTS_XTAL_CLOCK
config.clk_src = TIMER_SRC_CLK_APB;
#endif
timer_init(TIMER_GROUP_0, timer_idx, &config);
/* Timer's counter will initially start from value below.
Also, if auto_reload is set, this value will be automatically reload on alarm */
timer_set_counter_value(TIMER_GROUP_0, timer_idx, 0x00000000ULL);
/* Configure the alarm value and the interrupt on alarm. */
timer_set_alarm_value(TIMER_GROUP_0, timer_idx, timer_interval_sec * TIMER_SCALE);
timer_enable_intr(TIMER_GROUP_0, timer_idx);
timer_isr_register(TIMER_GROUP_0, timer_idx, timerGrp0Isr, (void*)timer_idx, ESP_INTR_FLAG_IRAM, NULL);
timer_start(TIMER_GROUP_0, timer_idx);
This is the ISR:
void IRAM_ATTR timerGrp0Isr(void *para){                            //This interrupt is handled by CPU1
int timer_idx = (int)para;
timer_spinlock_take(TIMER_GROUP_0);
//Wake acqAdc2 in order to start ADC readings from adc2. CPU0 will start immediatly acquiring
vTaskNotifyGiveFromISR(acquiring_2_task, (BaseType_t*)NULL);
//Wake acqAdc1 in order to start ADC readings form adc1. This will only start when this handler is terminated.
vTaskNotifyGiveFromISR(acquiring_1_task, (BaseType_t*)NULL);
//Clear the interrupt
timer_group_clr_intr_status_in_isr(TIMER_GROUP_0, timer_idx);
//After the alarm has been triggered we need enable it again, so it is triggered the next time
timer_group_enable_alarm_in_isr(TIMER_GROUP_0, timer_idx);
timer_spinlock_give(TIMER_GROUP_0);
And then, when acquiring_1_task receives the notification, it immediately disables the interrupt like so:
void acqAdc1(){
//Init Timer 0_1 (timer 1 from group 0) and register it's interupt handler
timerGrp0Init(TIMER_1, TIMER1_INTERVAL_SEC);
//Config all possible adc channels
configSixAdcChannels(ADC_RESOLUTION);
while(1){
if(ulTaskNotifyTake(pdTRUE, ONE_HOUR_MS/portTICK_PERIOD_MS ) == 1){ //THIS IS WHERE THE TASK RECIEVES THE NOTIFICATION
if(timer_disable_intr(TIMER_GROUP_0, 1) == ESP_OK){
printf("Disable ok\n");
//TODO clear acq_config.adc1_num_channels
}else{
DEBUG_PRINT(W, "acqAdc1", "ulTaskNotifyTake timed out!");
The thing is, I keep getting periodically the interruption after the disable has been made, does someone know what I'm doing wrong?
Thanks in advance
Users browsing this forum: Baidu [Spider], ChatGPT-User, PerplexityBot and 6 guests
