1.8TFT SPI 128x160 module SD-card and Display will not work together
ilioss
Postby ilioss » Sun Apr 19, 2020 9:08 am
In my project logging data from BME-280 and DS18B20 I found problems with the SD card and the TFT display.
ESP32 wroom32 dev.kit v1 DOIT wonderfull.
BME-280 and DS18B20 sensors.
Combined SD and TFT module 1.8 TFT SPI 128x160 with Async webserver,OTA,SPIFFS
The display works fine with OliKraus library Ucglib on Ucglib_ST7735_18x128x160 ( test )
The whole build together will give a malfunction on the SD card??? :roll:
Both SW_SPI and HW_SPI Oli Kraus GrapicsTest.ino works fine.
HW_SPI cd=4 , cs=15 , rst=12 note: only display
SW_SPI sclk=18 , data=23 , cd=4 , cs=15 , rst=12 note: only display
Combine test SD and Display
HW_SPI same pin as above used SD write and read works display came on delayed for 10 sec??
SW_SPI same ….. SD write and read works display will not work stay blank???????
flash read err, 1000
ets_main.c 371
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:8896
load:0x40080400,len:5816
entry 0x400806ac
SD Card Type: SDHC
SD Card Size: 3829MB
Listing directory: /
DIR : /System Volume Information
FILE: /-.CSV SIZE: 2233
FILE: /test.txt SIZE: 1048576
FILE: /foo.txt SIZE: 13
Creating Dir: /mydir
Dir created
DIR : /mydir
Removing Dir: /mydir
Dir removed
Listing directory: /System Volume Information
FILE: /System Volume Information/WPSettings.dat SIZE: 12
FILE: /System Volume Information/IndexerVolumeGuid SIZE: 76
Writing file: /hello.txt
File written
Appending to file: /hello.txt
Message appended
Reading file: /hello.txt
Read from file: Hello World!
Deleting file: /foo.txt
File deleted
Renaming file /hello.txt to /foo.txt
File renamed
Reading file: /foo.txt
1048576 bytes read for 3009 ms
1048576 bytes written for 5634 ms
Total space: 3821MB
Used space: 1MB
In my program I used the HW_SPI for SD and display will not work together.
[code// ****************** AsyncWebserver ******************
#include <AsyncEventSource.h>
#include <ESPAsyncWebServer.h>
#include <AsyncTCP.h>
// *************** DALLAS temp. *****************
#include <OneWire.h>
#include <DallasTemperature.h>
//***** WIFI *************
#include <WiFi.h>
#include <WiFiUdp.h> // nodig voor de tijd NTP
//***** OTA *************
#include <ArduinoOTA.h> // Over the air programming
//****** SPIFFS *******
#include <SPIFFS.h> // SPIFFS file flashen
//*********ESPmDNS **********
#include <ESPmDNS.h>
//************* FS ****************
#include <FS.h>
#include <FSImpl.h>
#include <vfs_api.h>
//*********** DISPLAY ************************
#include "Ucglib.h"
Ucglib_ST7735_18x128x160_HWSPI ucg(/*cd=*/ 4, /*cs=*/ 15, /*reset=*/ 12);
//Ucglib_ST7735_18x128x160_SWSPI ucg(/*sclk=*/ 18, /*data=*/ 23, /*cd=*/ 4, /*cs=*/ 15, /*reset=*/ 12);
// ***** SD ****************
#include <SD.h>
#include <sd_defines.h>
#include <sd_diskio.h>
#include <SPI.h>
#define CS_PIN 2 // chipselect pin gedefinieerd SD card
File dataFile;
File filename;
//***** TIME *****
#include <time.h>
long timezone = 1;
byte daysavetime = 1;
//*********** DALLAS temp. *************
#define TEMP_SENSOR_PIN 5
OneWire oneWire(TEMP_SENSOR_PIN); // Set up a OneWire instance to communicate with OneWire devices
DallasTemperature sensors(&oneWire); // Create an instance of the temperature sensor class
//*************** BME280*************************
#include <Wire.h>
#include <Adafruit_BME280.h>
#include <Adafruit_Sensor.h>
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BME280 bme; // I2C SDA=21 en SCL=22
//********* OTA *************
const char *OTAName = "ESP8266"; // A name and a password for the OTA service
const char *OTAPassword = "esp8266";
const char* mdnsName = "esp8266"; // Domain name for the mDNS responder
const char* ssid = "mmmmm"; // Replace with your network credentials
const char* password = "nnnnn";
const int ledPin = 13; // Set LED GPIO13
String ledState; // Stores LED state
String yy;
String mm;
String dd;
String hr;
String mi;
String se;
String dataMessage; // met gegevens om te loggen
String headerMessage; // file header met colom gegevens datum, tijd, tempbi,hum,press,tempbu
String tempbi; // van BME
String humidity; // van BME
String pressure; // van BME
String tempbu;
String temperature;
//************** FS ***********************
File fsUploadFile; // a File variable to temporarily store the received file
//************* WIFI server *******************
AsyncWebServer server(80);
// ********************* BME-280 *********************************
String getTemperature() { // Variable to store the HTTP request String header;
float temperature = bme.readTemperature();
Serial.println(temperature);
return String(temperature);
String getHumidity() {
float humidity = bme.readHumidity();
Serial.println(humidity);
return String(humidity);
String getPressure() {
float pressure = bme.readPressure()/ 100.0F;
Serial.println(pressure);
return String(pressure);
//********************** DS18B20 *************************************************
String readDSTemperatureC() { // Call sensors.requestTemperatures() to issue a global temperature and Requests to all devices on the bus
sensors.requestTemperatures();
float tempbu = sensors.getTempCByIndex(0);
Serial.println(tempbu);
return String(tempbu);
//************************** LED etc.*******************************************
String processor(const String& var){ // Replaces placeholder with LED state value
Serial.println(var);
if(var == "STATE"){ // var in index.html page (id)
if(digitalRead(ledPin)){
ledState = "ON";
else{
ledState = "OFF";
Serial.print(ledState);
return ledState;
else if (var == "TEMPERATURE"){ // var in index.html page (id)
return getTemperature(); // BME-280 temperature binnen
else if (var == "HUMIDITY"){ // var in index.html page (id)
return getHumidity();
else if (var == "PRESSURE"){ // var in index.html page (id)
return getPressure();
else if (var == "TEMPBU"){ // var in index.html page (id)
return readDSTemperatureC(); // DS18B20 buiten
//**************** SET-UP *******************
void setup(){
pinMode(ledPin, OUTPUT); // bool status;
pinMode(2, OUTPUT);
SPI.begin();
sensors.begin(); // Start up the DS18B20 library
bme.begin();
if (!bme.begin(0x76)) {
Serial.println("Could not find a valid BME280 sensor, check wiring!");
while (1);
startSD();
startWIFI();
ucg.begin(UCG_FONT_MODE_TRANSPARENT); // maakt achtergrond
ucg.setColor(0, 120, 0, 0);
ucg.setColor(2, 0, 120, 0);
ucg.setColor(1, 120, 0, 120);
ucg.setColor(3, 0, 120, 120);
ucg.drawGradientBox(0, 0, ucg.getWidth(), ucg.getHeight());
ArduinoOTA
.onStart([]() {
String type;
if (ArduinoOTA.getCommand() == U_FLASH)
type = "sketch";
else // U_SPIFFS
type = "filesystem";
// NOTE: if updating SPIFFS this would be the place to unmount SPIFFS using SPIFFS.end()
Serial.println("Start updating " + type);
.onEnd([]() {
Serial.println("\nEnd");
.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
else if (error == OTA_END_ERROR) Serial.println("End Failed");
ArduinoOTA.begin();
if(!SPIFFS.begin()){ // Initialize SPIFFS
Serial.println("An Error has occurred while mounting SPIFFS");
return;
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){ // Route for root / web page
request->send(SPIFFS, "/index.html", String(), false, processor);
server.on("/favicon.ico", HTTP_GET, [](AsyncWebServerRequest *request){ // was /favicon.ico
request->send(SPIFFS, "/favicon.png", "image/png");
server.on("/style.css", HTTP_GET, [](AsyncWebServerRequest *request){ // Route to load style.css file
request->send(SPIFFS, "/style.css", "text/css");
server.on("/on", HTTP_GET, [](AsyncWebServerRequest *request){ // Route to set GPIO to HIGH
digitalWrite(ledPin, HIGH);
server.on("/off", HTTP_GET, [](AsyncWebServerRequest *request){ // Route to set GPIO to LOW
digitalWrite(ledPin, LOW);
server.on("/temperature", HTTP_GET, [](AsyncWebServerRequest *request){ // Route to the BME Temperature
request->send_P(200, "text/plain", getTemperature().c_str());
server.on("/humidity", HTTP_GET, [](AsyncWebServerRequest *request){ // Route to the BME Humidity
request->send_P(200, "text/plain", getHumidity().c_str());
server.on("/pressure", HTTP_GET, [](AsyncWebServerRequest *request){ // Route to the BME Pressure
request->send_P(200, "text/plain", getPressure().c_str());
server.on("/tempbu", HTTP_GET, [](AsyncWebServerRequest *request){ // Route to the DS18B20 Temperature
request->send_P(200, "text/plain", readDSTemperatureC().c_str());
server.begin(); // Start server
//******************* LOOP *********************
void loop(){
ArduinoOTA.handle();
startTIME();
getReadings();
getBME();
useDisplay();
logSDCard();
//*************** VOIDS ***************
void startSD() {
SD.begin(2);
Serial.print("Initializing SD card...");
if (!SD.begin(2))
Serial.println("Card failed, or not present"); // see if the card is present and can be initialized:
while (1) ; // don't do anything more: nu mag door ook als er geen kaart is
Serial.println("card initialized.");
delay(10);
Serial.println("\r\n");
void startWIFI() {
WiFi.begin(ssid, password); // Connect to Wi-Fi
WiFi.mode(WIFI_STA);
delay(100); // was 1000
Serial.println("Connecting to WiFi..");
Serial.println(WiFi.localIP()); // Print ESP32 Local IP Address
Serial.println("Ready");
Serial.print("IP address: ");
void getReadings(){ // Function to get DS18B20 temperature
tempbu = sensors.getTempCByIndex(0); // Temperature in Celsius
void getBME() { // BME-280 readings
tempbi = bme.readTemperature();
void logSDCard() {
String path = "/" + mm + "-" + dd + ".csv";
headerMessage = "Tijd, Tempbu, \n";
dataMessage = String(dd) + String(tempbu)+"\r\n";
File file = SD.open(path.c_str());
if(!file) {
Serial.println("File doens't exist");
Serial.println("Creating file...");
writeFile(SD, path.c_str(), headerMessage.c_str());
else {
Serial.println("File already exists");
file.close();
if (dd != dd) { // nieuwe dag
else {
appendFile(SD, path.c_str(), dataMessage.c_str());
void useDisplay(){
delay(20);
ucg_int_t y = 0;
ucg_int_t h = 14;
ucg.setRotate270();
y += h;
ucg.setFontMode(UCG_FONT_MODE_TRANSPARENT);
ucg.setPrintPos(4,y);
ucg.setFont(ucg_font_helvB08_tr);
ucg.print("Pressure:");
ucg.setFontMode(UCG_FONT_MODE_SOLID);
ucg.setFont(ucg_font_7x13_mr);
ucg.setColor(0, 255, 255, 255); // use white as main color for the font
ucg.setColor(1, 64, 64, 255); // use blue as background for SOLID mode
ucg.setPrintPos(80,y);
ucg.print(pressure);
y += h;
ucg.print("Humidity:");
ucg.print(humidity);
y += h;
ucg.print("Temperature:");
ucg.print(tempbi);
y += h;
ucg.print("Temp. buiten:");
if (tempbu <= 20 ) {
ucg.setColor(0, 255, 40, 80);
ucg.setColor(1, 0, 255, 0);
ucg.setColor(2, 255, 0, 0);
ucg.setColor(3, 65, 255, 40);// 3,65,255,40
ucg.drawGradientBox(80-2, y-10, 40, 12);// red to green bar will erase the previous value
} else if(tempbu >20) {
ucg.setColor(3, 255, 40, 80);// 3,255,40,80
ucg.setColor(2, 0, 255, 0);
ucg.setColor(1, 255, 0, 0);
ucg.setColor(0, 65, 255, 40);
ucg.print(tempbu);
y += h;
ucg.print("Status LED:");
if (digitalRead(ledPin )) {
ucg.drawGradientBox(80-2, y-10, 40, 12); // red to green bar will erase the previous value
ucg.print("ON");
ucg.setPrintPos(100,y);
ucg.print("OFF");
void startmDNS() {
// Set up mDNS responder:
// - first argument is the domain name, in this example
// the fully-qualified domain name is "esp8266.local"
// - second argument is the IP address to advertise
// we send our IP address on the WiFi network
if (!MDNS.begin("esp32")) {
Serial.println("Error setting up MDNS responder!");
while(1) {
delay(100);
Serial.println("mDNS responder started");
server.begin(); // Start TCP (HTTP) server
Serial.println("TCP server started");
MDNS.addService("http", "tcp", 80); // Add service to MDNS-SD
void appendFile(fs::FS &fs, const char * path, const char * message) { // Append data to the SD card (DON'T MODIFY THIS FUNCTION)
Serial.println("");
Serial.printf("Appending to file: %s\n", path);
File file = fs.open(path, FILE_APPEND);
if(!file) {
Serial.println("Failed to open file for appending");
return;
if(file.print(message)) {
Serial.println("Message");
Serial.print(dataMessage.c_str());
Serial.println("Appended");
Serial.println("Append failed");
file.close();
void writeFile(fs::FS &fs, const char * path, const char * message) { // Write to the SD card (DON'T MODIFY THIS FUNCTION)
Serial.printf("Writing file: %s\n", path);
File file = fs.open(path, FILE_WRITE);
if(!file) {
Serial.println("Failed to open file for writing");
return;
Serial.println("File written");
Serial.println("Write failed");
file.close();
void startTIME() {
Serial.println("Contacting Time Server");
configTime(3600*timezone, daysavetime*3600, "time.nist.gov", "0.pool.ntp.org", "1.pool.ntp.org");
struct tm tmstruct ;
delay(100);
hr = (tmstruct.tm_hour);
mi = (tmstruct.tm_min);
se = (tmstruct.tm_sec);
tmstruct.tm_year = 0;
getLocalTime(&tmstruct, 5000);
Serial.printf("\nNow is : %d-%02d-%02d %02d:%02d:%02d\n",(tmstruct.tm_year)+1900,( tmstruct.tm_mon)+1, tmstruct.tm_mday,tmstruct.tm_hour , tmstruct.tm_min, tmstruct.tm_sec);
Serial.println("");
int yy = (tmstruct.tm_year)+1900;
String year;
year=String(yy);
Serial.println(year);
int mm = (tmstruct.tm_mon)+1;
String month;
month=String(mm);
Serial.println(month);
int dd = (tmstruct.tm_mday);
String day;
day=String(dd);
Serial.println(day);
//********* HELPER FUNCTIES **************************************
String formatBytes(size_t bytes) { // convert sizes in bytes to KB and MB
if (bytes < 1024) {
return String(bytes) + "B";
} else if (bytes < (1024 * 1024)) {
return String(bytes / 1024.0) + "KB";
} else if (bytes < (1024 * 1024 * 1024)) {
return String(bytes / 1024.0 / 1024.0) + "MB";
String getContentType(String filename) { // determine the filetype of a given filename, based on the extension
if (filename.endsWith(".html")) return "text/html";
else if (filename.endsWith(".css")) return "text/css";
else if (filename.endsWith(".js")) return "application/javascript";
else if (filename.endsWith(".ico")) return "image/x-icon";
else if (filename.endsWith(".gz")) return "application/x-gzip";
return "text/plain";
}][/code]
I already looked into the postings related to SD problems withgout any luck s.a SdFat from Greig.
Any help on this issue is more than welcome.
Like to hear,
ilioSS
ilioss
Re: 1.8TFT SPI 128x160 module SD-card and Display will not work together
Postby ilioss » Sat Apr 25, 2020 8:46 am
Hi all,
After some time to spent to solve this problem I found the solution in using he library from adafruit.
I found this in the Rui Santos TFT tutorial.
In fact I do not know why it didn,t work with the former libraries. :?
But at last I have a working project to read display and log the weather readings.
For me this issue is closed.
Regards,
ilioSS
Appending to file: /4-25.csv
Message
10:37:31,22.25,39.12,1016.02,20.50
Appended
// ***************  AsyncWebserver *******************
// ***************  DALLAS temp. *********************
//****************  WIFI *****************************
#include <WiFi.h>
//****************  OTA ******************************
//**************** SPIFFS ****************************
//**************** ESPmDNS  **************************
//**************** FS  *******************************
#include <FS.h>
#include <FSImpl.h>
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library for ST7735
#define TFT_CS        15
#define TFT_RST        12    // Or set to -1 and connect to Arduino RESET pin
#define TFT_DC         4
 Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
// *************** SD   ******************************
#include <SD.h>
#include <SPI.h>
//**************** TIME ******************************
#include <time.h>
long timezone = 1;
//**************** DALLAS temp. **********************
//**************** BME280 ****************************
#include <Wire.h>
//**************** OTA *******************************
const char* ssid     = "nnnnn";    // Replace with your network credentials
const char* password = "bbbbbbb";
String yy;
String year;
String mm;
String month;
String dd;
String day;
String hr;
String mi;
String se;
String tempbu;
String temperature;
//**************** FS ********************************
//**************** WIFI server ***********************
// *************** BME-280 ***************************
//**************** DS18B20 ***************************
  delay(20);
 delay(20);
//**************** LED  etc.**************************
      ledState = "ON";
    else{
      ledState = "OFF";
    return ledState;
//**************** SET-UP ****************************
 void setup(){
 pinMode(2, OUTPUT);
 SPI.begin();
 bme.begin();
    while (1);
 initSD();
 startWIFI();
 initTFT();
// startTIME();
 startOTA();
    return;
//****************  LOOP  ****************************
void loop(){
    delay(2000);
      mm = ( tmstruct.tm_mon)+1;
      dd = tmstruct.tm_mday;
  String year;
  year=String(yy);
  String month;
  month=String(mm);
  String day;
  day=String(dd);
    Serial.println("");
    String path = "/" + month + "-" + day + ".csv";  // format maand dag
    headerMessage = "Tijd, temperature,humidity,pressure,tempbu \n";              // tijd,temperature, humidity, pressure, tempbu
    dataMessage = String(hr) + ":" + String(mi) + ":" + String(se) + "," + String(temperature) + "," + String(humidity) + "," + String(pressure) + "," + String(tempbu)+ "\r\n";  // uur:minuut:sec,temperature, humidity, pressure, tempbu
     if(!file) {
    else {
    file.close();
    else {
      appendFile(SD, path.c_str(), dataMessage.c_str());// SD
 getReadings();
 getBME();
 displayText();
 delay(1000);
//**************** VOIDS *****************************
void startTIME() {
      delay(100);
      Serial.println("");
  String year;
  year=String(yy, DEC);
  Serial.println(yy);
  String month;
  month=String(mm);
  Serial.println(mm);
  String day;
  day=String(dd, DEC);
  Serial.println(dd);
 void startOTA(){
ArduinoOTA
    .onStart([]() {
      String type;
        type = "sketch";
      else                                // U_SPIFFS
      Serial.println("Start updating " + type);  // NOTE: if updating SPIFFS this would be the place to unmount SPIFFS using SPIFFS.end()
    .onEnd([]() {
  ArduinoOTA.begin();
 void initTFT(){
   tft.initR(INITR_BLACKTAB);   // initialize a ST7735S chip, black tab
   tft.setTextWrap(false); // Allow text to run off right edge
   tft.fillScreen(ST77XX_BLACK);
void displayText() {
    tft.setRotation(-45);
    tft.setCursor(0, 0);
    tft.setTextColor(ST77XX_RED);
    tft.setTextSize(2);
    tft.print("Temp:");
    tft.setTextColor(ST77XX_YELLOW);
    tft.setTextSize(2);
    tft.println(temperature);
    tft.setTextColor(ST77XX_GREEN);
    tft.setTextSize(2);
    tft.print("Hum: ");
    tft.setTextSize(2);
    tft.println(humidity);
    tft.setTextColor(ST77XX_BLUE);
    tft.setTextSize(2);
    tft.print("Pres:");
    tft.println(pressure);
    tft.setCursor(0,90);
    tft.setTextSize(2);
    tft.print("Tempbu:");
    tft.setTextSize(2);
    tft.println(tempbu);
    tft.setTextSize(1);
    tft.print(yy);
    tft.print(":");
    tft.print(mm);
    tft.print(":");
    tft.print(dd);
    tft.print("  ");
    tft.print(hr);
    tft.print("-");
    tft.print(mi);
    tft.print("-");
    tft.println(se);
void initSD() {
    SD.begin(2);
    if (!SD.begin(2))
    delay(10);
void startWIFI() {
   while (WiFi.waitForConnectResult() != WL_CONNECTED) {  // while (WiFi.status() != WL_CONNECTED)
    delay(5000);  // was 1000
     delay(20);
     delay(20);
void logSDCard()  {
     if(!file) {
    else {
    file.close();
    else {
void startmDNS() {
        while(1) {
            delay(100);
    Serial.println("");
    if(!file) {
    return;
    file.close();
     if(!file) {
     return;
     file.close();
  if (bytes < 1024) {
Users browsing this forum: ChatGPT-User, Semrush [Bot] and 3 guests
