wrover kit shematic V2 "SD Card"
Postby rudi ;-) » Sun Mar 26, 2017 9:40 pm
hi guys
after several times doing sd card things i have a time to look up on the shematic detailed and see,
that DATA2 is not pulled up ( NC )
i wounder me, is this cause GPIO12 or do we not need to pull up this line.
i remind to me, that ivan talked, we must pulled up all lines ( hope have understand well )
can you do a small state to this please?
thank you
Angus
Re: wrover kit shematic V2 "SD Card"
Postby Angus » Mon Mar 27, 2017 12:12 am
Hi Rudi,
IO12 is not pulled up on the board because it needs to be low on reset to enable 3.3V flash voltage. Refer to this note in the sd_card example README:
https://github.com/espressif/esp-idf/bl ... out-gpio12
I found that on my ESP-WROVER-KIT boards, the sd_card example worked without any software or hardware modifications. However you may get different behaviour with a different SD card.
If your card is still not working, check you have connected the SD_IO2 to IO2 jumper as described on page 8 of the ESP-WROVER-KIT getting started guide PDF: http://espressif.com/en/support/download/documents
Postby rudi ;-) » Mon Mar 27, 2017 12:21 am
hi Angus
txs for fast reply
I thought this into thoughts, cause gpio12, but was not sure.
yes can confirm, here sd card example works without modifikation on wrover.
thank you!
Users browsing this forum: PetalBot and 2 guests
