HI
I once posted a topic about gatts write attr value:viewtopic.php?f=2&t=1437
The function "esp_ble_gatts_set_attr_value" doesn't work.
Then i find that the code about "gatts write attr value" is empty in btc_gatts.c line 534.
So have ESP32 teams finished the work yet?
And when?
code about gatts set value,is empty
Re: code about gatts set value,is empty
hiHI
And when?
btc_gatts.c line 534 - what you mean with empty?
have you an error message for the line 534?
can u post your error line message?
rudi
edit: hint
JonathanChenNew
hiHI
And when?
rudi
edit: hint
Hi rudi
thanks for your reply!
my local code:
void btc_gatts_call_handler(btc_msg_t *msg)
btc_ble_gatts_args_t *arg = (btc_ble_gatts_args_t *)msg->arg;
switch (msg->act) {
case BTC_GATTS_ACT_APP_REGISTER: {
tBT_UUID uuid;
uuid.len = LEN_UUID_16;
uuid.uu.uuid16 = arg->app_reg.app_id;
BTA_GATTS_AppRegister(&uuid, btc_gatts_inter_cb);
case BTC_GATTS_ACT_APP_UNREGISTER:
BTA_GATTS_AppDeregister(arg->app_unreg.gatts_if);
case BTC_GATTS_ACT_CREATE_SERVICE: {
tBTA_GATT_SRVC_ID srvc_id;
btc_to_bta_srvc_id(&srvc_id, &arg->create_srvc.service_id);
BTA_GATTS_CreateService(arg->create_srvc.gatts_if, &srvc_id.id.uuid,
srvc_id.id.inst_id, arg->create_srvc.num_handle,
srvc_id.is_primary);
case BTC_GATTS_ACT_CREATE_ATTR_TAB:
btc_gatts_act_create_attr_tab(arg->create_attr_tab.gatts_attr_db,
arg->create_attr_tab.gatts_if,
arg->create_attr_tab.max_nb_attr,
arg->create_attr_tab.srvc_inst_id);
case BTC_GATTS_ACT_DELETE_SERVICE:
BTA_GATTS_DeleteService(arg->delete_srvc.service_handle);
case BTC_GATTS_ACT_START_SERVICE:
BTA_GATTS_StartService(arg->start_srvc.service_handle, BTA_GATT_TRANSPORT_LE);
case BTC_GATTS_ACT_STOP_SERVICE:
BTA_GATTS_StopService(arg->stop_srvc.service_handle);
case BTC_GATTS_ACT_ADD_INCLUDE_SERVICE:
BTA_GATTS_AddIncludeService(arg->add_incl_srvc.service_handle, arg->add_incl_srvc.included_service_handle);
case BTC_GATTS_ACT_ADD_CHAR: {
tBT_UUID uuid;
btc_to_bta_uuid(&uuid, &arg->add_char.char_uuid);
BTA_GATTS_AddCharacteristic(arg->add_char.service_handle, &uuid,
arg->add_char.perm, arg->add_char.property,
(tGATT_ATTR_VAL *)&arg->add_char.char_val,
(tBTA_GATTS_ATTR_CONTROL *)&arg->add_char.attr_control);
case BTC_GATTS_ACT_ADD_CHAR_DESCR: {
tBT_UUID uuid;
btc_to_bta_uuid(&uuid, &arg->add_descr.descr_uuid);
BTA_GATTS_AddCharDescriptor(arg->add_descr.service_handle, arg->add_descr.perm, &uuid,
(tBTA_GATT_ATTR_VAL *)&arg->add_descr.descr_val,
(tBTA_GATTS_ATTR_CONTROL *)&arg->add_descr.attr_control);
case BTC_GATTS_ACT_SEND_INDICATE:
BTA_GATTS_HandleValueIndication(arg->send_ind.conn_id, arg->send_ind.attr_handle,
arg->send_ind.value_len, arg->send_ind.value, arg->send_ind.need_confirm);
case BTC_GATTS_ACT_SEND_RESPONSE: {
esp_ble_gatts_cb_param_t param;
esp_gatt_rsp_t *p_rsp = arg->send_rsp.rsp;
if (p_rsp) {
tBTA_GATTS_RSP rsp_struct;
btc_to_bta_response(&rsp_struct, p_rsp);
BTA_GATTS_SendRsp(arg->send_rsp.conn_id, arg->send_rsp.trans_id,
arg->send_rsp.status, &rsp_struct);
param.rsp.handle = rsp_struct.attr_value.handle;
arg->send_rsp.status, NULL);
param.rsp.status = 0;
btc_gatts_cb_to_app(ESP_GATTS_RESPONSE_EVT, BTC_GATT_GET_GATT_IF(arg->send_rsp.conn_id), ¶m);
case BTC_GATTS_ACT_SET_ATTR_VALUE:
case BTC_GATTS_ACT_OPEN: {
// Ensure device is in inquiry database
tBTA_GATT_TRANSPORT transport = BTA_GATT_TRANSPORT_LE;
//TODO : implement address type and device type
#if 0
if (_get_address_type(arg->remote_bda, &addr_type) &&
btif_get_device_type(arg->remote_bda, &device_type) &&
device_type != BT_DEVICE_TYPE_BREDR) {
BTA_DmAddBleDevice(p_cb->bd_addr.address, addr_type, device_type);
#else
//BTA_DmAddBleDevice(p_cb->bd_addr.address, addr_type, device_type);
#endif
// Mark background connections
if (!arg->open.is_direct) {
BTA_DmBleSetBgConnType(BTM_BLE_CONN_AUTO, NULL);
// Connect!
BTA_GATTS_Open(arg->open.gatts_if, arg->open.remote_bda,
arg->open.is_direct, transport);
case BTC_GATTS_ACT_CLOSE:
// TODO : implement cancel open
// Cancel pending foreground/background connections
//BTA_GATTS_CancelOpen(p_cb->server_if, p_cb->bd_addr.address, TRUE);
//BTA_GATTS_CancelOpen(p_cb->server_if, p_cb->bd_addr.address, FALSE);
// Close active connection
if (arg->close.conn_id != 0) {
BTA_GATTS_Close(arg->close.conn_id);
default:
btc_gatts_arg_deep_free(msg);
as a ble client,the function is "void btc_gattc_cb_handler(btc_msg_t *msg)".
but in my case , it is a ble server,and the function is "void btc_gatts_call_handler(btc_msg_t *msg)"
https://github.com/espressif/esp-idf/bl ... tc_gatts.c
