[Q] esp32 embedded flash version
Postby rudi ;-) » Mon Mar 27, 2017 6:15 pm
D → Dual-core
0 → No internal flash
W → Wi-Fi
D → Dual-mode Bluetooth
Q → Quad Flat No-leads (QFN) package
6 → 6 mm × 6 mm package body size (QFN 48 pads)
5 → 5 mm × 5 mm package body size (QFN 48 pads)
hi guys,
we noted a long time ago from john lee, that there are variations on all of these, Dual Core , Single Core, without embedded Flash, with embedded Flash.
have you a knowledge about, when perhabs a test device / chipset is available/in plan
that have embedded flash inside the esp32, get this Dual or Single or for each then
we have then in future?
ESP32-D0WDQ
ESP32-D1WDQ
ESP32-S1WDQ
ESP32-S0WDQ
the note from esp32 datasheet
Note:
ESP32 chips with embedded flash do not support the address mapping between external flash and peripherals.
makes hope that there will be an embedded flash version soon :)
WiFive
Re: [Q] esp32 embedded flash version
Postby WiFive » Mon Mar 27, 2017 9:13 pm
What about the teaser for sip with embedded crystal, flash, decoupling, maybe even psram?
