CMakeList build system question
adesandr
Postby adesandr » Thu Apr 30, 2020 8:37 pm
Dev env : Linux Ubuntu 18.04
My project is structured like this :
Code: Untitled.cmake Select all
My_project :
subproject 1
main
main.c
file1.c
CMakeList.txt
CMakeList.txt
subproject 2
main
main.c
file 2.c
CMakeList.txt
CMakeList.txt
extra_component
Component1
file3.c
filee3.h
CMakeList.txt
Component2
file4.c
file4.h
CmakeList.txt
Both subproject (1&2) used the components inside the extra_components directories.
I used this scheme because my project need to build two different .bin to dowload two different board.
The Subproject CmainList is as follow :
cmake_minimum_required(VERSION 3.5)
set(PROJECT_VER "1.0.2")
set(EXTRA_COMPONENT_DIRS "${PROJECT_DIR}/../extra_components")
project(esp-mad-server)
The CmainList for the main component of the subproject is as follow :
idf_component_register(SRCS "main.c" "file1.c"
REQUIRES Component1 Component2)
When i try to build one subproject, Cmake failed with the following error :
CMake Error at /home/adesandr/esp-idf/tools/cmake/build.cmake:185 (message):
Failed to resolve component ‘Component1'.
I can’t understand that is wrong in my setup.
Thank you in advance for your help.
Regards.
adesandr
Re: CMakeList build system question
Postby adesandr » Fri May 01, 2020 1:01 pm
Env Dev : Linux Ubuntu 18.04 /ESP-IDF 4.00
My_project is structured as follow :
- My_Project/
- CMakeList.txt
- main/
- file1.c
- file1.h
- CMakeList.txt
- extra_components/
- component1/
- file2.c
- file2.h
- CMakeList.txt
- component2/
- file3.c
- file3.h
- CMakeList.txt
My_Project/CMakeList.txt is as follow :
	# The following lines of boilerplate have to be in your project's
# CMakeLists in this exact order for cmake to work correctly
# Project version
# Additional directorie to search for components
project(My_Project)
My_Project/main/CMakeList.txt is as follow
idf_component_register(SRCS "file1.c"
INCLUDE_DIRS " ")
/extra_components/component1/CMakeList.txt is as follow :
idf_component_register(SRCS "file2.c"
INCLUDE_DIRS "")
When i build My_Project, extra_components/component1and extra_component/component2 are not included in the components list, either in the components path ?
It seems that the command set(EXTRA_COMPONENT_DIRS "${PROJECT_DIR}/../extra_components") is not corrected interpreted.
If I change the structure of My_Project like in the ESP32 CMAKE build system documentation  :
- My_Project/
- CMakeList.txt
- main/
- file1.c
- file1.h
- CMakeList.txt
- components/
- component1/
- file2.c
- file2.h
- CMakeList.txt
- component2/
- file3.c
- file3.h
- CMakeList.txt
The build is working properly.
Regards.
Angus
Postby Angus » Fri May 15, 2020 2:26 am
Hi adesandr,
Thanks for being patient while someone got back to you.
I think the problem is here:
The PROJECT_DIR is not set as a variable in this file, it's only set as a build property (see API for getting build properties.)
If you look closely at the build output log, there should be some error about failing to find directory "/../extra_components".
Suggest the following should work:
# Additional directory to search for components
set(EXTRA_COMPONENT_DIRS "${CMAKE_SOURCE_DIR}/../extra_components")
Angus
adesandr
Postby adesandr » Sun May 31, 2020 6:08 pm
Thank you very much ESP_Angus, it was the problem.
It's very curious because it works under windows (${PROJECT_DIR}, but not under Linux. Maybe under windows PROJECT_DIR is set in the PATH, i will check.
Problem solved :P
Regards.
Users browsing this forum: Amazon [Bot] and 1 guest
