PCB Antenna Tuning
Brento
PCB Antenna Tuning
Postby Brento » Sun May 03, 2020 3:51 am
I'm trying to tune an antenna as seen above, using this wonderful Smith Chart Tool. It needs to match 35 + 10j characteristic impedance.
I have found a tool like the Microstrip Impedance Calculator to determine the impedance of the transmission lines.
However, i am unsure how to determine the characteristic impedance of the stubs that don't have a ground plane (green area) behind them. Does anyone know how that impedance is calculated?
MCUism
Re: PCB Antenna Tuning
Postby MCUism » Sun May 03, 2020 5:28 pm
Hey brento,
Not able to see the image you uploaded
Brento
Postby Brento » Sun May 03, 2020 8:51 pm
It should work now. Thanks for the notification!
Brento
Postby Brento » Mon May 04, 2020 2:20 am
I have heard on another forum, that my notion of what a 'stub' was, was incorrect. The antenna, is not a stub, but a stub is something above a ground plane.
With that in mind, does that mean that when I use the Smith Chart Tool, that I can consider the illustrated antenna to have zero impedance in the modelling?
Beowulff
Postby Beowulff » Fri Jun 05, 2020 1:04 am
Look here: https://www.ti.com/lit/an/swra638/swra6 ... 1318797718
But, this going to be an approximation at best. Once you get close, you are going to need to make a board and actually measure it’s performance.
