maximum input clock pulse any gpio on ESP32
KamalS
Postby KamalS » Thu May 14, 2020 5:09 pm
i'm trying to decode ws2811 signal
check image
https://imgur.com/a/3oHC8qd
read each byte & store in sd card (during 50us reset pulse of ws2811 protocol)
Low Pulse = 0.4us High + 0.85us Low
High Pulse = 0.8us High + 0.45us Low
Reset = >50 us
24 bit for each led (RGB each 8bit = 24)
its Clock Pulse rate nearly 800Kbps
FF00FF (Green= all bit high,Red = 00 all bit low, Green = FF all bit high)
possible>> reading performance will get batter by disable all other stacks which will handled by processor?
all i want to know that what is maximum input signal interrupt count?
note:
no any other parallel process(1: sd card writing)
no wifi/bt ware used.
Re: maximum input clock pulse any gpio on ESP32
Postby Sprite » Fri May 15, 2020 7:15 am
Suggest you use the RMT for this instead.
