Why GPIO data types must be defined again in Arduino environment?
insanoff
Postby insanoff » Fri May 22, 2020 9:21 pm
Hi Everyone,
I tried to execute the following example code from the Arduino environment, but it threw a data type error ESP32_freeRTOS_test:50:21: error: cannot convert 'GPIO_INT_TYPE' to 'gpio_int_type_t' in assignment for all GPIO configuration lines. I fixed them by adding the appropriate data types. Another problem was the definition of the pins, as I had to change them to GPIO_NUM_xx type.
But why it doesn't work for me? What difference in Arduino causes the problem?
Thanks!
Adam
Original code: https://github.com/espressif/esp-idf/bl ... ple_main.c
My adapted working code:
/* GPIO Example
   URL: https://github.com/espressif/esp-idf/blob/master/examples/peripherals/gpio/main/gpio_example_main.c
#define GPIO_OUTPUT_IO_0				GPIO_NUM_2
#define GPIO_OUTPUT_PIN_SEL				(1ULL<<GPIO_OUTPUT_IO_0)
#define GPIO_INPUT_IO_0					GPIO_NUM_34
#define GPIO_INPUT_PIN_SEL				(1ULL<<GPIO_INPUT_IO_0)
#define ESP_INTR_FLAG_DEFAULT			0
static xQueueHandle gpio_evt_queue = NULL;
static void IRAM_ATTR gpio_isr_handler(void* arg)
  uint32_t gpio_num = (uint32_t) arg;
  xQueueSendFromISR(gpio_evt_queue, &gpio_num, NULL);
static void gpio_task_example(void* arg)
  uint32_t io_num;
  for (;;) {
    if (xQueueReceive(gpio_evt_queue, &io_num, portMAX_DELAY)) {
      printf("GPIO[%d] intr, val: %d\n", io_num, gpio_get_level((gpio_num_t)io_num));
  gpio_config_t io_conf;
  //disable interrupt
  io_conf.intr_type = (gpio_int_type_t)GPIO_PIN_INTR_DISABLE;
  //set as output mode
  io_conf.mode = GPIO_MODE_OUTPUT;
  //bit mask of the pins that you want to set,e.g.GPIO18/19
  io_conf.pin_bit_mask = GPIO_OUTPUT_PIN_SEL;
  //disable pull-down mode
  io_conf.pull_down_en = (gpio_pulldown_t)0;
  //disable pull-up mode
  io_conf.pull_up_en = (gpio_pullup_t)0;
  //configure GPIO with the given settings
  gpio_config(&io_conf);
  //interrupt of rising edge
  io_conf.intr_type = (gpio_int_type_t)GPIO_PIN_INTR_POSEDGE;
  //bit mask of the pins, use GPIO4/5 here
  io_conf.pin_bit_mask = GPIO_INPUT_PIN_SEL;
  //set as input mode
  io_conf.mode = GPIO_MODE_INPUT;
  //enable pull-up mode
  io_conf.pull_up_en = (gpio_pullup_t)1;
  //change gpio intrrupt type for one pin
  gpio_set_intr_type(GPIO_INPUT_IO_0, GPIO_INTR_ANYEDGE);
  //create a queue to handle gpio event from isr
  gpio_evt_queue = xQueueCreate(10, sizeof(uint32_t));
  //start gpio task
  xTaskCreate(gpio_task_example, "gpio_task_example", 2048, NULL, 10, NULL);
  //install gpio isr service
  gpio_install_isr_service(ESP_INTR_FLAG_DEFAULT);
  //hook isr handler for specific gpio pin
  gpio_isr_handler_add(GPIO_INPUT_IO_0, gpio_isr_handler, (void*) GPIO_INPUT_IO_0);
  //remove isr handler for gpio number.
  gpio_isr_handler_remove(GPIO_INPUT_IO_0);
  //hook isr handler for specific gpio pin again
  int cnt = 0;
  while (1) {
    printf("cnt: %d\n", cnt++);
    vTaskDelay(1000 / portTICK_RATE_MS);
    gpio_set_level(GPIO_OUTPUT_IO_0, cnt % 2);
  //  gpio_set_direction(LED_PIN, GPIO_MODE_OUTPUT);
void loop() {}
insanoff
Re: Why GPIO data types must be defined again in Arduino environment?
Postby insanoff » Sat May 23, 2020 12:16 am
OK, I got it. That's because Arduino uses C++, but ESP32 code is written in C.
Users browsing this forum: Applebot and 6 guests
